> Hell Hole Update, Suggestions on the suspension ear?
bandjoey
post Oct 6 2008, 10:58 AM
bandjoey
Well, after a summer of spending all of my time and money remodeling the house, I'm finally working on the 914 again. Look at the P.O.'s work. 1/4" steel plate for the inside fender and top of the long, and little else in the way of rust control.
Help Guys!...Look at the suspension ear support. The bottom is rusted through. The P.O. did a wonderful job of making a support brace out of what looks like 20g steel and welded it over the long, connecting the inside and outside together. It probably gave added strength at the time but how to replace the support now?
If I cut on the Yellow Dashes, will the new piece from RD (or does anyone here have one for sale?) fit up to that line, or does it lap over the seam??? How much of the outside will I be needing to cut out if it goes over the seam? The outside support, with the 3 bolt holes, look solid as a rock. It looks good inside the long at that area.
The good news is it's centrally located and fixable. Just forward of this point everything look solid.
Also...look at the engine support on the long. Anyone got one of these laying around? Imagine that side of the engine falling off. The support hole is rusted through.
I've got all the sheet metal pieces up to these 2 from RD and Engman already, and a new set of pans. If there's anyone in the DFW area that's already done this and just can't keep their hands off of 914 restorations, feel free to call and stop by.
Bill (IMG:style_emoticons/default/welder.gif)
r_towle
post Oct 6 2008, 11:19 AM
Custom Member
That "patch" is stock.
Its a standard item that ties in inner and outers.
If you replace the inner, you need to make those again, they are no available, but as you see its pretty simple to fabricate.
For your car I would suggest you look at buying the inner fender from AA, the rest you can fabricate but the inner fender has some funky contours for the battery tray that are a bitch to get right.
Rich
- Lo-Fi Version Time is now: 1st July 2025 - 01:11 PM
