'75 L-Jet running rich "Smog Test Blues", OK I should of started this thread 3 days ago |
tabs914 |
Oct 8 2008, 12:35 AM
Advertise Your Drive... Group: Members Posts: 105 Joined: 17-January 05 From: Gresham, Oregon Member No.: 3,456 Region Association: None |
Gang, I need your help. I started out just running rich. So I made a very small adjustment to the AFM to lean it out. I also did a tune-up (cap, rotor, plugs and wires) No points (Compufire). I also replaced my ol faithful Bosch Blue Coil (12 years old) with the best I could find in a day (Standard Brand). Now I am running rich and with a nice case of hesitation and blubbering. Idle is good, but the minute I pull on the throttle a slight decrease on the RPM for a second then it picks up and blubbers at what ever point I pull the throttle up to. It does it at all RPM's. I haven't got on any stretch of road long enough to see if I can feel any hunting or jerking...I am almost certain that it would. I have tried to find posts on the site and I can't find any with my symptoms.
I checked all the vacuum lines for leaks.(cut old ends off and reattached) Checked the Pressure Regulator, vacuum side for leaks. Cleaned the throttle body (also made a rubber gasket for it) Cleaned the throttle switch (removed all the carbon deposits on the points.) Checked the AFM Flap for any damage (have you checked the price on these babies? Ouch!) I am at a loss...any advice you might have would greatly be appreciated. Thanks in advance... (IMG:style_emoticons/default/blink.gif) |
tabs914 |
Oct 12 2008, 10:19 PM
Well all day tracing back to when the blubbering started, I remembered checking the relays on the relay board on the left side in the engine bay. I had taken them out to clean the connections and reseat them. I was thinking mabe I might have a bad one that is causing the blubbering. So I moved them around one by one and it started to run real rough. So I adjusted the CO screw and idle and tried the throttle.......no more blubbering. So I will take her down to DEQ and see what happens. Thanks for all your help...I wish I could buy you all a cold one. (IMG:style_emoticons/default/beerchug.gif)
Steve I might take you up on your offer if all else fails. That is really kind of you. (IMG:style_emoticons/default/piratenanner.gif) Wish me luck... |
ClayPerrine |
Oct 13 2008, 07:14 AM
Life's been good to me so far..... Group: Admin Posts: 15,515 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Well all day tracing back to when the blubbering started, I remembered checking the relays on the relay board on the left side in the engine bay. I had taken them out to clean the connections and reseat them. I was thinking mabe I might have a bad one that is causing the blubbering. So I moved them around one by one and it started to run real rough. So I adjusted the CO screw and idle and tried the throttle.......no more blubbering. So I will take her down to DEQ and see what happens. Thanks for all your help...I wish I could buy you all a cold one. (IMG:style_emoticons/default/beerchug.gif) Steve I might take you up on your offer if all else fails. That is really kind of you. (IMG:style_emoticons/default/piratenanner.gif) Wish me luck... Uhh.. I can tell you that is not the problem. The relays in the relay board do NOTHING for the Fuel Injection on an L-jet car. |
Lo-Fi Version | Time is now: 8th June 2024 - 09:26 AM |
