'75 L-Jet running rich "Smog Test Blues", OK I should of started this thread 3 days ago |
tabs914 |
Oct 8 2008, 12:35 AM
Advertise Your Drive... Group: Members Posts: 105 Joined: 17-January 05 From: Gresham, Oregon Member No.: 3,456 Region Association: None |
Gang, I need your help. I started out just running rich. So I made a very small adjustment to the AFM to lean it out. I also did a tune-up (cap, rotor, plugs and wires) No points (Compufire). I also replaced my ol faithful Bosch Blue Coil (12 years old) with the best I could find in a day (Standard Brand). Now I am running rich and with a nice case of hesitation and blubbering. Idle is good, but the minute I pull on the throttle a slight decrease on the RPM for a second then it picks up and blubbers at what ever point I pull the throttle up to. It does it at all RPM's. I haven't got on any stretch of road long enough to see if I can feel any hunting or jerking...I am almost certain that it would. I have tried to find posts on the site and I can't find any with my symptoms.
I checked all the vacuum lines for leaks.(cut old ends off and reattached) Checked the Pressure Regulator, vacuum side for leaks. Cleaned the throttle body (also made a rubber gasket for it) Cleaned the throttle switch (removed all the carbon deposits on the points.) Checked the AFM Flap for any damage (have you checked the price on these babies? Ouch!) I am at a loss...any advice you might have would greatly be appreciated. Thanks in advance... (IMG:style_emoticons/default/blink.gif) |
tabs914 |
Oct 14 2008, 01:24 PM
PASS PASS PASS (IMG:style_emoticons/default/piratenanner.gif) ...it took me three times, but I passed barely on the second idle test 285 ppm on HC. 300 is the max... I retarded the distributor and upped the idle to compensate. Runs like crap now...I will have to retime it again and enrich when I get home. Thanks again for all your help. I don’t know if this thread is going to be of any help to anyone having the same problem as I, but it was a good experience, learned a few things along the way and met a lot of great people.
Note: Keep that throttle body clean. The breather ( idle screw ) mine was all closed up with grim. I can hear it again. It makes like a turbo “Chirp” sound. I like it... (IMG:style_emoticons/default/driving.gif) |
Lo-Fi Version | Time is now: 8th June 2024 - 01:41 PM |
