echocanyons |
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,094 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California ![]() ![]() ![]() |
I have a 75 with a 1.8 & l-jet.
I recently purchased this car as a non-runner but in good overall structural condition. I am now at the point where it cranks by the key and I get spark and fuel but the injectors are not functioning. the checklist of things I have checked are: 1. Compression, good all the way around 2. Spark, also good all the way around 3. Fuel, good pressure, fuel pump runns when the AFM flap is moved and when the starter is engaged. 4. ignition switch replaced by me for a non-functioning one. 5. The dual relay were replace by a used unit that seems to work 6. The thing I know is wrong is, the injectors are not opening or getting a charge to open. I understand that normally the signal to power the injectors comes from the coil & they open twice per crank rotation in a non-sequential fashion. Are they powered by the ECU as well? Where should I start looking next? I bet if I can get the injectors to fire this puppy will start right up. |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,594 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
Get two baby food jars..the little glass ones...or an equivelent.
Remove the AFM from the intake boot Remove the fuel injectors from the intake manifold, passenger side. Place both injectors in the baby food jars. Using a pencil, hold the flapper door open on the AFM. Turn key on...you should hear the fuel pump running. Remove high tension coil wire from coil to distributor have someone turn over car like you are trying to start it. Watch the injectors to see if they are firing and spraying correctly. Rich |
echocanyons |
finished the spray test, all looks good.
It must have been a loose connection at the resistor pack because the seem to spray now. It ran for the first time under my watch (IMG:style_emoticons/default/aktion035.gif) progress feels good (IMG:style_emoticons/default/biggrin.gif) I sounds like it has a nasty exhaust leak though. |
Lo-Fi Version | Time is now: 17th June 2024 - 08:10 AM |
