rjames |
I'm made of metal ![]() ![]() ![]() ![]() Group: Members Posts: 4,305 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest ![]() ![]() |
When removing the gas tank for a sway bar install I noticed that the fuel pump on my '75 had a different colored wire hooked up to it, and a stray wire not going to anything. It has always worked fine, so I ignored it. Then I learned that the fuel pump is supposed to shut itself off after a few seconds with the key in the 'on' position. Mine doesn't do that, it just runs continuously. While I do want undo whatever the PO did and wire it correctly, I don't have time to do anything now. My questions is will this hurt anything assuming I actually start the car and don't just leave the ignition in the position without it running? Thanks- Robert |
rjames |
The car still has it's original FI system in tact.
QUOTE My vote is to fix it and forget it. Yeah, I guess I need to figure it out and put it back to the way it should be. Maybe it was just a bad relay or something similarily simple that caused somebody to run another wire to it... |
southernmost914 |
KEY WEST/HAVANA Tunnel Authority ![]() ![]() Group: Members Posts: 338 Joined: 16-October 07 From: Key West/ St. Augie, Fl USA Member No.: 8,234 Region Association: South East States ![]() ![]() |
The car still has it's original FI system in tact. QUOTE My vote is to fix it and forget it. Yeah, I guess I need to figure it out and put it back to the way it should be. Maybe it was just a bad relay or something similarily simple that caused somebody to run another wire to it... This was a Qwick fix on the 1.8 when the dual fuel pump relay failed. Not correct but will work. (IMG:style_emoticons/default/bye1.gif) Steve |
Lo-Fi Version | Time is now: 6th July 2025 - 02:16 PM |
