rjames |
I'm made of metal ![]() ![]() ![]() ![]() Group: Members Posts: 4,305 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest ![]() ![]() |
When removing the gas tank for a sway bar install I noticed that the fuel pump on my '75 had a different colored wire hooked up to it, and a stray wire not going to anything. It has always worked fine, so I ignored it. Then I learned that the fuel pump is supposed to shut itself off after a few seconds with the key in the 'on' position. Mine doesn't do that, it just runs continuously. While I do want undo whatever the PO did and wire it correctly, I don't have time to do anything now. My questions is will this hurt anything assuming I actually start the car and don't just leave the ignition in the position without it running? Thanks- Robert |
wertygrog |
wertygrog ![]() ![]() Group: Members Posts: 429 Joined: 12-November 05 From: Long Beach, CA Member No.: 5,114 Region Association: Southern California ![]() |
So is there a relay that runs the pump for 2 seconds or so, or does the FI brain do this? Where is this fuel pump relay- on the engine compartment relay board I presume?
southernmost914 |
KEY WEST/HAVANA Tunnel Authority ![]() ![]() Group: Members Posts: 338 Joined: 16-October 07 From: Key West/ St. Augie, Fl USA Member No.: 8,234 Region Association: South East States ![]() ![]() |
So is there a relay that runs the pump for 2 seconds or so, or does the FI brain do this? Where is this fuel pump relay- on the engine compartment relay board I presume? Maybe this will help. 1.7 and 2.0 D-jet ![]() 74 and 75 1.8 use a dual relay mounted by the battery stand. Steve |
Lo-Fi Version | Time is now: 6th July 2025 - 10:13 AM |
