trans Mount: This does not look right., 914-6 conversion not right |
bfrymire |
Oct 5 2008, 08:19 PM
Salsaholic Group: Members Posts: 590 Joined: 1-August 04 From: Sunnyvale, CA Member No.: 2,431 Region Association: Northern California |
Hello All,
I have a 914-6 conversion that I bought from someone. Well, looking at the rear trans mount, it's off the posts. This does not look right. Any ideas of whta is wrong and what I need to do to correct. (this does not look safe.) The engine appears to be mounted in the correct place and everything else looks ok. I am thinking that the rear mount is the wrong one??? Here's a pic. I really hope someone can point me in the right direction. -- brett |
GeorgeRud |
Nov 2 2008, 09:45 PM
Advanced Member Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
That looks like a home-made front engine mount. I had a similar mount on my car before I switched to a Rich Johnson mount. The Quick-Six mount is of that type, and they do the job, just not as nice as the better mounts that isolate the engine like Porsche did in their mounts.
I'd change out the front mount rather than play with the transmission mount. It's just a symptom of the problem in front. Does the sheetmetal around the engine bay fit correctly? |
bfrymire |
Nov 2 2008, 10:49 PM
That looks like a home-made front engine mount. I had a similar mount on my car before I switched to a Rich Johnson mount. The Quick-Six mount is of that type, and they do the job, just not as nice as the better mounts that isolate the engine like Porsche did in their mounts. I'd change out the front mount rather than play with the transmission mount. It's just a symptom of the problem in front. Does the sheetmetal around the engine bay fit correctly? THere is a slight gap at the front. And I do suspect that the mount is homemade. I was looking at the mount on Pelican Parts website to see what it should look like. I will look at the Rick Johnson mount. Thanks for the input. -- brett |
Lo-Fi Version | Time is now: 10th June 2024 - 10:20 PM |
