| '73-914kid |
Nov 8 2008, 08:47 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,473 Joined: 1-November 08 From: Vista, CA Member No.: 9,714 Region Association: Southern California |
Okay guys.....I'm letting the motor bit set, so I'm on to suspesnion (something I can actually work on right now) and I need a new set of trailing arm bushings.
I was looking into the Weltmeister Polygraphite bushings because they were a decent price. Anyone have other opinions on these bushings or other ones for below $80? I would love poly-bronze bushings but $260 from pelicanis just a little steep (IMG:style_emoticons/default/laugh.gif) |
| Joe Ricard |
Nov 9 2008, 05:53 PM
CUMONIWANNARACEU ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
not going to find new rubber. unless you buy a whole new trailing arm.
Get the poly and install a grease fitting it will last at least a year. I did something similair to the McMaster carr pieces. I used steel bushings with grease clearance of .002 and of coourse a zerk. No stick, no bind, no play. Lots of noise from the road. |
'73-914kid Polygraphite rear bushings? Nov 8 2008, 08:47 AM
Dave_Darling They stick, they squeak, and they're a bit of ... Nov 8 2008, 10:06 AM
r_towle
Okay guys.....I'm letting the motor bit set, ... Nov 8 2008, 11:04 AM
J P Stein Yes, Dave, they ain't worth shit, however........ Nov 8 2008, 11:13 AM
r_towle
Yes, Dave, they ain't worth shit, however....... Feb 9 2009, 06:03 PM
J P Stein
3-4 years now...still swing like butter.
Rich
... Feb 9 2009, 06:09 PM
jimkelly is bronze $260 per side with axle - or ... Nov 8 2008, 01:32 PM
Lou W
is bronze $260 per side with axle - or ... Nov 8 2008, 01:59 PM
Eric_Shea Here's my take on the level of quality on the ... Nov 8 2008, 02:09 PM
TC 914-8
With the harder poly bushings you will need to p... Nov 13 2008, 07:17 PM
Eric_Shea :wttc: BTW Nov 8 2008, 02:14 PM
'73-914kid The car is going to be a daily driver for the stre... Nov 9 2008, 05:24 PM
Eric_Shea
Elephant Racing does rubber now. If you don... Nov 9 2008, 06:08 PM
Gint
Elephant Racing does rubber now. If you don't... Nov 9 2008, 07:14 PM
r_towle
[quote name='Eric_Shea' post='1100398' date='Nov ... Nov 9 2008, 07:21 PM
Eric_Shea Lou,
I think your outside zerks are on 180 degree... Nov 9 2008, 06:10 PM
ConeDodger
Lou,
I think your outside zerks are on 180 degre... Nov 9 2008, 07:21 PM
Lou W
Lou,
I think your outside zerks are on 180 degre... Nov 9 2008, 07:22 PM
ConeDodger
Lou,
I think your outside zerks are on 180 degr... Nov 9 2008, 07:28 PM
Lou W
[quote name='Lou W' post='1100446' date='Nov 9 20... Nov 9 2008, 07:37 PM
wbergtho
This is what I did and haven't had a problem... Nov 9 2008, 06:16 PM
Eric_Shea
Agree... if you want the ultimate restoration de... Nov 9 2008, 07:18 PM
Eric_Shea
I don't think they're a DIY item. It so... Nov 9 2008, 09:05 PM
r_towle
I don't think they're a DIY item. It sou... Nov 10 2008, 10:08 AM
Eric_Shea
Yup, and that's the cheap guys.
I think it... Nov 10 2008, 10:20 AM
r_towle
I think it... Nov 10 2008, 10:47 AM
Eric_Shea That's exactly what our last conversation was.... Nov 10 2008, 10:57 AM
jimkelly ERMP-2051500 Elephant Racing, Front PolyBronze Sus... Nov 13 2008, 06:54 PM
Eric_Shea Tony,
Those are the items I use to hone out the s... Nov 13 2008, 07:44 PM
TC 914-8 Yep, I was just surfing their site and got side tr... Nov 13 2008, 08:02 PM
Eric_Shea
Yup.
It sounds like he put the 94D poly bushing... Nov 13 2008, 08:08 PM
dashgod I'm just about to tackle this project myself. ... Feb 3 2009, 06:03 PM
Krieger914 I don't have any photos, but have had weltmei... Feb 3 2009, 07:40 PM
Eric_Shea Here's a write up on it. I like the sanding d... Feb 4 2009, 03:53 PM
SirAndy I've been running the roller bearings (now Fre... Feb 4 2009, 04:15 PM
r_towle
I've been running the roller bearings (now Fr... Feb 5 2009, 09:37 PM
degreeoff does anyone know off the top of their heads what s... Feb 4 2009, 04:17 PM
andys Josh,
You'll also need a new pivot shaft made... Feb 4 2009, 05:01 PM
Racer Chris
I believe someone here makes those as well.
An... Feb 4 2009, 06:40 PM
jmill
does anyone know off the top of their heads what ... Feb 4 2009, 05:18 PM
degreeoff
does anyone know off the top of their heads what... Feb 4 2009, 05:44 PM
[quote name='jmill' post='1130107' date='Feb 4 20... Feb 4 2009, 05:54 PM
jmill I can take measurements. I don't believe it... Feb 4 2009, 05:55 PM
I can take measurements. I don't believe it... Feb 4 2009, 05:59 PM
jmill
You guys do realize that you can't use the st... Feb 4 2009, 06:04 PM
Eric_Shea Both shafts and arms are in consistent. I've ... Feb 4 2009, 06:09 PM
degreeoff BTW..... :hijacked: .....sorry
It looks like th... Feb 4 2009, 09:12 PM
It looks like that is how its done here.....a cou... Feb 4 2009, 09:21 PM
degreeoff Did McMark design and market that design? Feb 4 2009, 09:42 PM
Mike M... Feb 4 2009, 10:06 PM
Eric_Shea I believe Harvey Shine (sic) first developed the w... Feb 4 2009, 10:48 PM
Racer Chris
I believe Harvey Shine (sic) first developed the ... Feb 5 2009, 08:11 AM
Racer Chris More than 50% of the trailing arm pivot shafts we ... Feb 5 2009, 09:08 AM
Racer Chris Our delrin bushings have a light press fit into th... Feb 5 2009, 09:18 AM
degreeoff dat dare is preety schwanky my man! Feb 5 2009, 09:44 AM
jmill
Both shafts and arms are in consistent. I've... Feb 5 2009, 10:43 AM
andys Perhaps someone has cut open a pivot shaft, but a ... Feb 5 2009, 02:32 PM
finstermojo I purchased some bushings a while back about a yea... Feb 5 2009, 04:47 PM
Eric_Shea
How much did you pay?
Here's the real deter... Feb 5 2009, 07:47 PM
charliew I know this started as a rear bushing thread but t... Feb 5 2009, 09:17 PM
finstermojo So this is a picture of the bushing i purchased ov... Feb 9 2009, 04:49 PM
Eric_Shea Pretty obvious. ;)
That's a perfect example ... Feb 9 2009, 04:53 PM
finstermojo I just ordered a set of hard bushings from your pl... Feb 9 2009, 05:51 PM
Eric_Shea
No fronts sorry. Feb 9 2009, 07:06 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:41 AM |
