| '73-914kid |
Nov 8 2008, 08:47 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,473 Joined: 1-November 08 From: Vista, CA Member No.: 9,714 Region Association: Southern California |
Okay guys.....I'm letting the motor bit set, so I'm on to suspesnion (something I can actually work on right now) and I need a new set of trailing arm bushings.
I was looking into the Weltmeister Polygraphite bushings because they were a decent price. Anyone have other opinions on these bushings or other ones for below $80? I would love poly-bronze bushings but $260 from pelicanis just a little steep (IMG:style_emoticons/default/laugh.gif) |
| Eric_Shea |
Nov 9 2008, 06:08 PM
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
QUOTE not going to find new rubber. unless you buy a whole new trailing arm. Elephant Racing does rubber now. If you don't like the price of their poly-bronze you won't like the rubber. http://www.elephantracing.com/suspension/r...berbushings.htm They are the only ones I know of doing it for the 914 right now. QUOTE Get the poly and install a grease fitting it will last at least a year. The harder poly will probably last a lifetime. They are extremely hard at 70D (rated at 9000lbs). There is no flex, no stick or bind when honed properly so it would be more like Joes metal bushings. I've done dozens now and they slide up and down in the mounts with one finger ease. http://www.pmbperformance.com/catalog/item...565/5297602.htm Standard 94A polys flex a lot, you can squeeze them with your hand. Those are the ones that will last a year or two. |
| Gint |
Nov 9 2008, 07:14 PM
Mike Ginter ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,106 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
QUOTE not going to find new rubber. unless you buy a whole new trailing arm. Elephant Racing does rubber now. If you don't like the price of their poly-bronze you won't like the rubber. http://www.elephantracing.com/suspension/r...berbushings.htm They are the only ones I know of doing it for the 914 right now. That price isn't bad actually. IMO anyway... |
'73-914kid Polygraphite rear bushings? Nov 8 2008, 08:47 AM
Dave_Darling They stick, they squeak, and they're a bit of ... Nov 8 2008, 10:06 AM
r_towle
Okay guys.....I'm letting the motor bit set, ... Nov 8 2008, 11:04 AM
J P Stein Yes, Dave, they ain't worth shit, however........ Nov 8 2008, 11:13 AM
r_towle
Yes, Dave, they ain't worth shit, however....... Feb 9 2009, 06:03 PM
J P Stein
3-4 years now...still swing like butter.
Rich
... Feb 9 2009, 06:09 PM
jimkelly is bronze $260 per side with axle - or ... Nov 8 2008, 01:32 PM
Lou W
is bronze $260 per side with axle - or ... Nov 8 2008, 01:59 PM
Eric_Shea Here's my take on the level of quality on the ... Nov 8 2008, 02:09 PM
TC 914-8
With the harder poly bushings you will need to p... Nov 13 2008, 07:17 PM
Eric_Shea :wttc: BTW Nov 8 2008, 02:14 PM
'73-914kid The car is going to be a daily driver for the stre... Nov 9 2008, 05:24 PM
Joe Ricard not going to find new rubber. unless you buy a wh... Nov 9 2008, 05:53 PM
r_towle
[quote name='Eric_Shea' post='1100398' date='Nov ... Nov 9 2008, 07:21 PM
Eric_Shea Lou,
I think your outside zerks are on 180 degree... Nov 9 2008, 06:10 PM
ConeDodger
Lou,
I think your outside zerks are on 180 degre... Nov 9 2008, 07:21 PM
Lou W
Lou,
I think your outside zerks are on 180 degre... Nov 9 2008, 07:22 PM
ConeDodger
Lou,
I think your outside zerks are on 180 degr... Nov 9 2008, 07:28 PM
Lou W
[quote name='Lou W' post='1100446' date='Nov 9 20... Nov 9 2008, 07:37 PM
wbergtho
This is what I did and haven't had a problem... Nov 9 2008, 06:16 PM
Eric_Shea
Agree... if you want the ultimate restoration de... Nov 9 2008, 07:18 PM
Eric_Shea
I don't think they're a DIY item. It so... Nov 9 2008, 09:05 PM
r_towle
I don't think they're a DIY item. It sou... Nov 10 2008, 10:08 AM
Eric_Shea
Yup, and that's the cheap guys.
I think it... Nov 10 2008, 10:20 AM
r_towle
I think it... Nov 10 2008, 10:47 AM
Eric_Shea That's exactly what our last conversation was.... Nov 10 2008, 10:57 AM
jimkelly ERMP-2051500 Elephant Racing, Front PolyBronze Sus... Nov 13 2008, 06:54 PM
Eric_Shea Tony,
Those are the items I use to hone out the s... Nov 13 2008, 07:44 PM
TC 914-8 Yep, I was just surfing their site and got side tr... Nov 13 2008, 08:02 PM
Eric_Shea
Yup.
It sounds like he put the 94D poly bushing... Nov 13 2008, 08:08 PM
dashgod I'm just about to tackle this project myself. ... Feb 3 2009, 06:03 PM
Krieger914 I don't have any photos, but have had weltmei... Feb 3 2009, 07:40 PM
Eric_Shea Here's a write up on it. I like the sanding d... Feb 4 2009, 03:53 PM
SirAndy I've been running the roller bearings (now Fre... Feb 4 2009, 04:15 PM
r_towle
I've been running the roller bearings (now Fr... Feb 5 2009, 09:37 PM
degreeoff does anyone know off the top of their heads what s... Feb 4 2009, 04:17 PM
andys Josh,
You'll also need a new pivot shaft made... Feb 4 2009, 05:01 PM
Racer Chris
I believe someone here makes those as well.
An... Feb 4 2009, 06:40 PM
jmill
does anyone know off the top of their heads what ... Feb 4 2009, 05:18 PM
degreeoff
does anyone know off the top of their heads what... Feb 4 2009, 05:44 PM
[quote name='jmill' post='1130107' date='Feb 4 20... Feb 4 2009, 05:54 PM
jmill I can take measurements. I don't believe it... Feb 4 2009, 05:55 PM
I can take measurements. I don't believe it... Feb 4 2009, 05:59 PM
jmill
You guys do realize that you can't use the st... Feb 4 2009, 06:04 PM
Eric_Shea Both shafts and arms are in consistent. I've ... Feb 4 2009, 06:09 PM
degreeoff BTW..... :hijacked: .....sorry
It looks like th... Feb 4 2009, 09:12 PM
It looks like that is how its done here.....a cou... Feb 4 2009, 09:21 PM
degreeoff Did McMark design and market that design? Feb 4 2009, 09:42 PM
Mike M... Feb 4 2009, 10:06 PM
Eric_Shea I believe Harvey Shine (sic) first developed the w... Feb 4 2009, 10:48 PM
Racer Chris
I believe Harvey Shine (sic) first developed the ... Feb 5 2009, 08:11 AM
Racer Chris More than 50% of the trailing arm pivot shafts we ... Feb 5 2009, 09:08 AM
Racer Chris Our delrin bushings have a light press fit into th... Feb 5 2009, 09:18 AM
degreeoff dat dare is preety schwanky my man! Feb 5 2009, 09:44 AM
jmill
Both shafts and arms are in consistent. I've... Feb 5 2009, 10:43 AM
andys Perhaps someone has cut open a pivot shaft, but a ... Feb 5 2009, 02:32 PM
finstermojo I purchased some bushings a while back about a yea... Feb 5 2009, 04:47 PM
Eric_Shea
How much did you pay?
Here's the real deter... Feb 5 2009, 07:47 PM
charliew I know this started as a rear bushing thread but t... Feb 5 2009, 09:17 PM
finstermojo So this is a picture of the bushing i purchased ov... Feb 9 2009, 04:49 PM
Eric_Shea Pretty obvious. ;)
That's a perfect example ... Feb 9 2009, 04:53 PM
finstermojo I just ordered a set of hard bushings from your pl... Feb 9 2009, 05:51 PM
Eric_Shea
No fronts sorry. Feb 9 2009, 07:06 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:41 AM |
