rjames |
I'm made of metal ![]() ![]() ![]() ![]() Group: Members Posts: 4,305 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest ![]() ![]() |
When removing the gas tank for a sway bar install I noticed that the fuel pump on my '75 had a different colored wire hooked up to it, and a stray wire not going to anything. It has always worked fine, so I ignored it. Then I learned that the fuel pump is supposed to shut itself off after a few seconds with the key in the 'on' position. Mine doesn't do that, it just runs continuously. While I do want undo whatever the PO did and wire it correctly, I don't have time to do anything now. My questions is will this hurt anything assuming I actually start the car and don't just leave the ignition in the position without it running? Thanks- Robert |
rock914 |
rock914 ![]() Group: Members Posts: 36 Joined: 28-October 08 From: Hoopeston Ill Member No.: 9,695 Region Association: None ![]() |
Strange you would mention not putting a relay in the FP socket???? When I started working on the car there was not one there. I just thought that it had been removed by the last owner when he was working on the fuel system. Will the pump work without the relay in that position if everything else is working correctly? Is the dual relay tied into the fuel pump circuit in some way and able to bypass the need for that relay? My electrical prints leave a lot to be desired when it comes to the interface between the controller and the fuel pump.
Thanks!! Bob |
Lo-Fi Version | Time is now: 6th July 2025 - 10:14 AM |
