Front BMW brakes locking front wheels all the time, why...please guys can i have your advice? |
budman5201 |
Nov 13 2008, 09:07 PM
Senior Member Group: Members Posts: 595 Joined: 1-April 07 From: tempe, az Member No.: 7,635 |
I recently bought new rear calipers, redid the front BMW brakes up front and installed HAWK race pads up front. The braking has significantly improved! YES! but now i have one dilema......The front brakes lock up EASILY and the rears never at all..........I wish i could make all them lock up in emergency situations or at least more Braking in the rear.
Did i just significantly make the front brakes better by installing new race pads and BMW brakes? Can i adjust anything with the stock rear system to get more pressure to the back so i dont lock up the front VERY EASILY??? thanks guys i appreciate your help..... Stock 1.7 liter GOING SUBARU 2.5 200 hp N/A soon!! Trying to make everything else PERFECT before i get my third Subaru done.....The braking was lacking on my last conversion...... thanks! Attached image(s) |
Eric_Shea |
Nov 14 2008, 11:13 AM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Kyle,
Do you have a firm pedal issue? If so I would look to the shut-off valve and measures to make sure air is out of it. Regarding the locking - Dave Sprinkle had this same problem and his pads weren't bedded in yet. For his street car I recommended the Ceramic pads which he eventually thought were "good" (once they bedded) but not great. He ended up not liking them because they were very dusty. I have the same situation on my wife's Mercedes wagon. I "really" liked the ceramics but they are dusty. I think they're the best in-expensive pad solution at around $35.00 Back on target, you should have great pads, I would be concerned that they've yet to bed in as R4-S's are one of the best pads out there. The only other person I heard of with a similar problem was Dave and he reported back as mentioned above. Regarding the bench bleed and the pedal. You mention bleeding so I mention pedal. I don't think the master cylinder would be an issue. I have a theory on 914 brake bleeding that I want to look into this weekend. If I'm correct and I can come up with a solution this could solve the spongey pedal thing. It involves the shut-off valve. Work on getting the rears bled and bed in the pads and you should be good to go. |
Lo-Fi Version | Time is now: 2nd June 2024 - 09:49 PM |
