Front BMW brakes locking front wheels all the time, why...please guys can i have your advice? |
budman5201 |
Nov 13 2008, 09:07 PM
Senior Member Group: Members Posts: 595 Joined: 1-April 07 From: tempe, az Member No.: 7,635 |
I recently bought new rear calipers, redid the front BMW brakes up front and installed HAWK race pads up front. The braking has significantly improved! YES! but now i have one dilema......The front brakes lock up EASILY and the rears never at all..........I wish i could make all them lock up in emergency situations or at least more Braking in the rear.
Did i just significantly make the front brakes better by installing new race pads and BMW brakes? Can i adjust anything with the stock rear system to get more pressure to the back so i dont lock up the front VERY EASILY??? thanks guys i appreciate your help..... Stock 1.7 liter GOING SUBARU 2.5 200 hp N/A soon!! Trying to make everything else PERFECT before i get my third Subaru done.....The braking was lacking on my last conversion...... thanks! Attached image(s) |
Eric_Shea |
Nov 21 2008, 10:49 AM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
QUOTE You should not need any enhanced cooling such as the AJ setup unless you track the car. One thing to watch out for with high performance pads is squealing. I have a set of KFP race pads on my street car right now that squeal badly at 30mph or less. I have to slightly disagree with Eric on the rear pad clearance. IMO .008" is correct and proper per the factory manual. Except he has BMW calipers now with about 40% more pad up front on the same rotor. I agree however, probably not needed for regular street duty even with the BMW calipers. .008" was the original spec. in the manual but they (Porsche) sent out a TSB revising that number after the manual was printed. All of the Haynes and Clymer folks picked up the .008" as well. Later the factory revised to .004" -or- basically the thickness of a business card vs. two business cards. I doubt there would be much difference as the mechanism in the piston allows for much more travel but, as the pads wear you may eventually have handbrake issues. .008 - .004. Either one is better than where 80% of them are set right now. (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 13th June 2024 - 04:03 AM |
