> Manual Fuel pump switch, and tips
ONTHEGRIND
post Nov 22 2008, 01:20 PM
so I am installing a new bosch fuel pump for my factory fuel injection system.. Where my factory fuel pump used to one in the stock location, one of the mounting tabs is gone from a little bit of rust, so I am moving it to the firewall. And mounting it with sheet metal screws.. Any body have a manual fuel pump switch wired up so if that relay crap decides not to work I can just flip it on with a switch.. where do you have it mounted and how do you have it wired up ?
Thanks
ONTHEGRIND
post Nov 22 2008, 05:34 PM
I have been cleaning the grounds as Igo threw it cleaned the one behind the battery still no pump.
ONTHEGRIND   Manual Fuel pump switch   Nov 22 2008, 01:20 PM
ONTHEGRIND   Nobody has done a manual switch ? I just put in a...   Nov 22 2008, 03:52 PM
Dave_Darling   There are two relays that control the fuel pump. ...   Nov 22 2008, 04:41 PM
ONTHEGRIND   There are two relays that control the fuel pump. ...   Nov 22 2008, 06:53 PM
southernmost914   There are two relays that control the fuel pump....   Nov 22 2008, 07:06 PM
ONTHEGRIND   Dave I am not looking to hack I am looking to f...   Nov 22 2008, 04:58 PM
markb   As Dave stated, if the board goes bad, having the ...   Nov 22 2008, 05:08 PM
r_towle   get two new relays. Put on in the correct socket f...   Nov 22 2008, 05:20 PM
ONTHEGRIND   Hmm instresting car was driving fine took it for...   Nov 22 2008, 05:21 PM
markb   The car is new to you. It probably has been sittin...   Nov 22 2008, 05:24 PM
ONTHEGRIND   I have been cleaning the grounds as Igo threw i...   Nov 22 2008, 05:34 PM
Spoke   Most folks don't do a manual switch because it...   Nov 22 2008, 06:07 PM
ONTHEGRIND   Most folks don't do a manual switch because i...   Nov 22 2008, 06:14 PM
Spoke   No I have not tried that yet what do I do take a...   Nov 22 2008, 06:28 PM
markb   There's a ground post in front and below the r...   Nov 22 2008, 06:25 PM
ONTHEGRIND   I put a wire from tb4 to a ground when I put it ...   Nov 22 2008, 06:40 PM
Spoke   I put a wire from tb4 to a ground when I put it...   Nov 22 2008, 10:40 PM
bperry   I put a wire from tb4 to a ground when I put it...   Nov 23 2008, 03:32 AM
Spoke   Pin II and IV are tied together and are +12v whil...   Nov 23 2008, 08:22 AM
McMark   To really solve the issue, you're gonna need t...   Nov 23 2008, 12:12 AM
ONTHEGRIND   THank you for the replies I am up at 7:30 gonna h...   Nov 23 2008, 09:36 AM
Dave_Darling   Which fuel injection system does your car have? T...   Nov 23 2008, 06:44 PM
ONTHEGRIND   I went on pbanders page started to work from the ...   Nov 23 2008, 06:52 PM
ONTHEGRIND   As you can see I moved the pump and added some new...   Nov 23 2008, 07:00 PM
ONTHEGRIND   In the book it shows it going the other way ? top...   Nov 23 2008, 07:29 PM
ONTHEGRIND   Swaped the lines droped the car put 2 gallons of f...   Nov 23 2008, 07:43 PM
markb   If the fuel lines were as bad as you say, you need...   Nov 23 2008, 10:38 PM
Dave_Darling   The filter you have on there is a cheap low-pressu...   Nov 24 2008, 12:40 AM
ONTHEGRIND   The filter you have on there is a cheap low-press...   Nov 24 2008, 12:55 AM
ONTHEGRIND   Car Runs but seems to have still have a problem....   Dec 1 2008, 07:38 PM
Cap'n Krusty   Car Runs but seems to have still have a problem...   Dec 1 2008, 07:42 PM
ONTHEGRIND   Car Runs but seems to have still have a proble...   Dec 1 2008, 07:59 PM
ONTHEGRIND   Swapped the fuse to red firred it up made it ten ...   Dec 1 2008, 08:10 PM
ONTHEGRIND   Any guess ?   Dec 2 2008, 10:19 AM
Spoke   You mentioned wd40 everything. For electrical item...   Dec 2 2008, 11:03 AM
ONTHEGRIND   Spoke I also have heen doing that the reason f...   Dec 2 2008, 11:19 AM
ONTHEGRIND   http://smg.photobucket.com/albums/v236/xr8...nt=10...   Dec 2 2008, 11:31 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 05:08 PM
