> Manual Fuel pump switch, and tips
ONTHEGRIND
post Nov 22 2008, 01:20 PM
so I am installing a new bosch fuel pump for my factory fuel injection system.. Where my factory fuel pump used to one in the stock location, one of the mounting tabs is gone from a little bit of rust, so I am moving it to the firewall. And mounting it with sheet metal screws.. Any body have a manual fuel pump switch wired up so if that relay crap decides not to work I can just flip it on with a switch.. where do you have it mounted and how do you have it wired up ?
Thanks
Dave_Darling
post Nov 22 2008, 04:41 PM
914 Idiot
There are two relays that control the fuel pump. One of them powers up the whole FI system, so if "the relay crap" decides not to work your chances are about 50/50 that none of the FI will work even if you convince the pump to run.
Fix the problem correctly, don't hack in a band-aid.
--DD
ONTHEGRIND
post Nov 22 2008, 06:53 PM
QUOTE(Dave_Darling @ Nov 22 2008, 02:41 PM) *
--DD
Where can I find these relays Mr. Darling ?
ONTHEGRIND   Manual Fuel pump switch   Nov 22 2008, 01:20 PM
ONTHEGRIND   Nobody has done a manual switch ? I just put in a...   Nov 22 2008, 03:52 PM
Dave_Darling   There are two relays that control the fuel pump. ...   Nov 22 2008, 04:41 PM
ONTHEGRIND   There are two relays that control the fuel pump. ...   Nov 22 2008, 06:53 PM
southernmost914   There are two relays that control the fuel pump....   Nov 22 2008, 07:06 PM
ONTHEGRIND   Dave I am not looking to hack I am looking to f...   Nov 22 2008, 04:58 PM
markb   As Dave stated, if the board goes bad, having the ...   Nov 22 2008, 05:08 PM
r_towle   get two new relays. Put on in the correct socket f...   Nov 22 2008, 05:20 PM
ONTHEGRIND   Hmm instresting car was driving fine took it for...   Nov 22 2008, 05:21 PM
markb   The car is new to you. It probably has been sittin...   Nov 22 2008, 05:24 PM
ONTHEGRIND   I have been cleaning the grounds as Igo threw i...   Nov 22 2008, 05:34 PM
Spoke   Most folks don't do a manual switch because it...   Nov 22 2008, 06:07 PM
ONTHEGRIND   Most folks don't do a manual switch because i...   Nov 22 2008, 06:14 PM
Spoke   No I have not tried that yet what do I do take a...   Nov 22 2008, 06:28 PM
markb   There's a ground post in front and below the r...   Nov 22 2008, 06:25 PM
ONTHEGRIND   I put a wire from tb4 to a ground when I put it ...   Nov 22 2008, 06:40 PM
Spoke   I put a wire from tb4 to a ground when I put it...   Nov 22 2008, 10:40 PM
bperry   I put a wire from tb4 to a ground when I put it...   Nov 23 2008, 03:32 AM
Spoke   Pin II and IV are tied together and are +12v whil...   Nov 23 2008, 08:22 AM
McMark   To really solve the issue, you're gonna need t...   Nov 23 2008, 12:12 AM
ONTHEGRIND   THank you for the replies I am up at 7:30 gonna h...   Nov 23 2008, 09:36 AM
Dave_Darling   Which fuel injection system does your car have? T...   Nov 23 2008, 06:44 PM
ONTHEGRIND   I went on pbanders page started to work from the ...   Nov 23 2008, 06:52 PM
ONTHEGRIND   As you can see I moved the pump and added some new...   Nov 23 2008, 07:00 PM
ONTHEGRIND   In the book it shows it going the other way ? top...   Nov 23 2008, 07:29 PM
ONTHEGRIND   Swaped the lines droped the car put 2 gallons of f...   Nov 23 2008, 07:43 PM
markb   If the fuel lines were as bad as you say, you need...   Nov 23 2008, 10:38 PM
Dave_Darling   The filter you have on there is a cheap low-pressu...   Nov 24 2008, 12:40 AM
ONTHEGRIND   The filter you have on there is a cheap low-press...   Nov 24 2008, 12:55 AM
ONTHEGRIND   Car Runs but seems to have still have a problem....   Dec 1 2008, 07:38 PM
Cap'n Krusty   Car Runs but seems to have still have a problem...   Dec 1 2008, 07:42 PM
ONTHEGRIND   Car Runs but seems to have still have a proble...   Dec 1 2008, 07:59 PM
ONTHEGRIND   Swapped the fuse to red firred it up made it ten ...   Dec 1 2008, 08:10 PM
ONTHEGRIND   Any guess ?   Dec 2 2008, 10:19 AM
Spoke   You mentioned wd40 everything. For electrical item...   Dec 2 2008, 11:03 AM
ONTHEGRIND   Spoke I also have heen doing that the reason f...   Dec 2 2008, 11:19 AM
ONTHEGRIND   http://smg.photobucket.com/albums/v236/xr8...nt=10...   Dec 2 2008, 11:31 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 06:37 PM
