| ONTHEGRIND |
Nov 22 2008, 01:20 PM
Member ![]() ![]() Group: Members Posts: 286 Joined: 10-November 08 From: California Member No.: 9,738 Region Association: None |
so I am installing a new bosch fuel pump for my factory fuel injection system.. Where my factory fuel pump used to one in the stock location, one of the mounting tabs is gone from a little bit of rust, so I am moving it to the firewall. And mounting it with sheet metal screws.. Any body have a manual fuel pump switch wired up so if that relay crap decides not to work I can just flip it on with a switch.. where do you have it mounted and how do you have it wired up ?
Thanks |
| ONTHEGRIND |
Nov 22 2008, 06:40 PM
I put a wire from tb4 to a ground when I put it in the plug in the lower left nothing happens when I turn the ignition to the on pos. I hear a click from the relays.. I toched a wire to the top connectors on tb4 and got sparks
| Spoke |
Nov 22 2008, 10:40 PM
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,370 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None
I put a wire from tb4 to a ground when I put it in the plug in the lower left nothing happens when I turn the ignition to the on pos. I hear a click from the relays.. I toched a wire to the top connectors on tb4 and got sparks Please elaborate on your findings: When you say nothing happens you mean the pump did not run. Correct? You hear a click from both relays? The spark is good and bad. Good that you had power there; bad cause shorting that pin to ground could damage the FI relay as it provides 12V to this pin from the battery with no fuse. There is a fuse on the relay board that powers the fuel pump. Is this fuse ok? Do you have a voltmeter? If not, buy one, you'll need it to work on your 914. |
ONTHEGRIND Manual Fuel pump switch Nov 22 2008, 01:20 PM
ONTHEGRIND Nobody has done a manual switch ? I just put in a... Nov 22 2008, 03:52 PM
Dave_Darling There are two relays that control the fuel pump. ... Nov 22 2008, 04:41 PM
ONTHEGRIND
There are two relays that control the fuel pump. ... Nov 22 2008, 06:53 PM
southernmost914
There are two relays that control the fuel pump.... Nov 22 2008, 07:06 PM
ONTHEGRIND Dave I am not looking to hack I am looking to f... Nov 22 2008, 04:58 PM
markb As Dave stated, if the board goes bad, having the ... Nov 22 2008, 05:08 PM
r_towle get two new relays.
Put on in the correct socket f... Nov 22 2008, 05:20 PM
ONTHEGRIND Hmm instresting car was driving fine took it for... Nov 22 2008, 05:21 PM
markb The car is new to you. It probably has been sittin... Nov 22 2008, 05:24 PM
ONTHEGRIND I have been cleaning the grounds as Igo threw i... Nov 22 2008, 05:34 PM
Spoke Most folks don't do a manual switch because it... Nov 22 2008, 06:07 PM
ONTHEGRIND
Most folks don't do a manual switch because i... Nov 22 2008, 06:14 PM
Spoke
No I have not tried that yet what do I do take a... Nov 22 2008, 06:28 PM
markb There's a ground post in front and below the r... Nov 22 2008, 06:25 PM
bperry
I put a wire from tb4 to a ground when I put it... Nov 23 2008, 03:32 AM
Spoke
Pin II and IV are tied together and are +12v whil... Nov 23 2008, 08:22 AM
McMark To really solve the issue, you're gonna need t... Nov 23 2008, 12:12 AM
ONTHEGRIND THank you for the replies I am up at 7:30 gonna h... Nov 23 2008, 09:36 AM
Dave_Darling Which fuel injection system does your car have? T... Nov 23 2008, 06:44 PM
ONTHEGRIND I went on pbanders page started to work from the ... Nov 23 2008, 06:52 PM
ONTHEGRIND As you can see I moved the pump and added some new... Nov 23 2008, 07:00 PM
ONTHEGRIND In the book it shows it going the other way ? top... Nov 23 2008, 07:29 PM
ONTHEGRIND Swaped the lines droped the car put 2 gallons of f... Nov 23 2008, 07:43 PM
markb If the fuel lines were as bad as you say, you need... Nov 23 2008, 10:38 PM
Dave_Darling The filter you have on there is a cheap low-pressu... Nov 24 2008, 12:40 AM
ONTHEGRIND
The filter you have on there is a cheap low-press... Nov 24 2008, 12:55 AM
ONTHEGRIND Car Runs but seems to have still have a problem.... Dec 1 2008, 07:38 PM
Cap'n Krusty
Car Runs but seems to have still have a problem... Dec 1 2008, 07:42 PM
ONTHEGRIND
Car Runs but seems to have still have a proble... Dec 1 2008, 07:59 PM
ONTHEGRIND Swapped the fuse to red firred it up made it ten ... Dec 1 2008, 08:10 PM
ONTHEGRIND Any guess ? Dec 2 2008, 10:19 AM
Spoke You mentioned wd40 everything. For electrical item... Dec 2 2008, 11:03 AM
ONTHEGRIND Spoke I also have heen doing that the reason f... Dec 2 2008, 11:19 AM
ONTHEGRIND http://smg.photobucket.com/albums/v236/xr8...nt=10... Dec 2 2008, 11:31 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 05:17 PM |
