> Custom Exhaust, just want to see what people have done
turnaround89
post Nov 21 2008, 12:55 AM
I am wondering if it would be possible to fab up my own exhaust system for my 1.8L engine. I figure i might be able to save some money this way, instead of buying a brand new one from AA or whomever and i'll learn how to make an exhaust as well. Just wanted to see what other people have done and how they went about it. Pictures would be great. I plan on getting rid of the heat exchangers if that helps out at all!
Thanks in advance everybody!!
turnaround89
post Nov 23 2008, 12:44 PM
I like the sound of the supertrapp, 1.) does the different ID for the tube affect the supertrapp at all or 2.) is that just for different exhaust setups, some with larger tubes other with smaller tubes? I figured it was the second one, but might as well ask.
I think i might buy a super trapp and work on getting the headers from the 4-1 setup.
Chris Hamilton
post Nov 23 2008, 01:27 PM
QUOTE(turnaround89 @ Nov 23 2008, 10:44 AM) *
They just offer different sizes according to what your exhaust system looks like. I think they recommend you use different size plates for different horsepower engines.
I'm using this muffler on both my honda and 914 http://store.summitracing.com/partdetail.a...mp;autoview=sku
With the honda I'm running 3 plates and it's nearly as quiet as the stock muffler the car came with. On the 914 I'm running 4 plates, and you can hardly hear the exhaust over my 40mm dellortos. I originally started with 6 plates in each car, and removing plates just kept increasing torque quite nicely.
I'm sure you'll be able to find the right combination according to what you plan to use the car for. My car has a stock cam and nicely ported heads, so it seems to like a bit of backpressure. Going from 6 plates to 4 seemed to improve the torque, but it still has pretty good top end up to the rev limiter ( 7,000 ).
turnaround89   Custom Exhaust   Nov 21 2008, 12:55 AM
jd74914   Well, first off you will need to make some flanges...   Nov 21 2008, 01:29 AM
Jake Raby   This is a huge challenge. The Type 4 engine is hea...   Nov 21 2008, 06:49 AM
spare time toys   Here are some down and dirty musts: -Primary l...   Nov 22 2008, 03:09 AM
CliffBraun   Here are some down and dirty musts: -Primary ...   Nov 22 2008, 11:40 AM
jd74914   Seconded, mine works fine. :D Fine is a relati...   Nov 22 2008, 12:24 PM
CliffBraun   Seconded, mine works fine. :D Fine is a relat...   Nov 22 2008, 12:54 PM
rick 918-S   As usual, Jake is the man. I've done some head...   Nov 21 2008, 09:18 AM
turnaround89   Ok, so what i have got so far it that all the cyli...   Nov 21 2008, 02:20 PM
A&PGirl   When my car was running it had a custom exhaust wh...   Nov 21 2008, 05:45 PM
Krieger914   Find yourself some used stainless heat exchangers ...   Nov 21 2008, 07:44 PM
jd74914   Find yourself some used stainless heat exchangers...   Nov 21 2008, 07:55 PM
worn   Find yourself some used stainless heat exchanger...   Oct 17 2018, 02:46 PM
mepstein   [quote name='jd74914' post='1104184' date='Nov 21...   Oct 18 2018, 06:11 AM
maf914   Thread is 10 years old. :lol: Yes it is! ...   Oct 18 2018, 07:50 AM
ChrisFoley   Thread is 10 years old. :lol: Yes it is! ...   Oct 18 2018, 08:48 AM
maf914   [quote name='maf914' post='2658426' date='Oct 18 ...   Oct 19 2018, 08:34 AM
Phoenix 914-6GT   Find yourself some used stainless heat exchangers...   Nov 21 2008, 08:00 PM
Hydra   What is dictated as the primary? apparently the...   Nov 22 2008, 02:42 AM
Krieger914   I love it ! You could polish the heck out of...   Nov 22 2008, 09:12 AM
Krieger914   I got a bursch at the time because it was a steal ...   Nov 22 2008, 09:26 AM
Phoenix 914-6GT   I got a bursch at the time because it was a steal...   Nov 22 2008, 01:16 PM
A&PGirl   Here are the pictures of my custom cherry bomb exh...   Nov 22 2008, 09:47 AM
jd74914   Its very possible I'm wrong and thinking about...   Nov 22 2008, 01:07 PM
ONTHEGRIND   We are working on a set of SS turbo manifolds a...   Nov 22 2008, 01:23 PM
r_towle   If you are planning on a custom exhaust system whi...   Nov 22 2008, 01:29 PM
Jake Raby   The Supertrapp has never impressed me. When they q...   Nov 22 2008, 01:29 PM
Chris Hamilton   The Supertrapp has never impressed me. When they ...   Nov 22 2008, 02:26 PM
KaptKaos   I just got a eurorace 4 into 1. What should I sti...   Nov 22 2008, 02:14 PM
Jake Raby   I will email the company I did the work for to see...   Nov 22 2008, 02:41 PM
Chris Hamilton   I will email the company I did the work for to se...   Nov 22 2008, 02:49 PM
Jake Raby   I will email the company I did the work for to s...   Nov 22 2008, 06:32 PM
CliffBraun   [quote name='Chris Hamilton' post='1104410' date=...   Nov 22 2008, 06:52 PM
turnaround89   I may not have posted this but i don't plan on...   Nov 22 2008, 03:40 PM
r_towle   Well, you need a header. 4-1 is easier to build a...   Nov 22 2008, 03:53 PM
turnaround89   I totally understand that a company won't rele...   Nov 22 2008, 05:51 PM
Jake Raby   That doesn't take much at all... BUT it actu...   Nov 22 2008, 07:48 PM
Chris Hamilton   That doesn't take much at all... BUT it act...   Nov 22 2008, 08:03 PM
turnaround89   Say i actually am able to make my own exhaust syst...   Nov 22 2008, 09:04 PM
CliffBraun   Say i actually am able to make my own exhaust sys...   Nov 22 2008, 09:10 PM
LarryR   Say i actually am able to make my own exhaust sys...   Nov 23 2008, 06:25 PM
turnaround89   Is a super trapp the same thing found on most tune...   Nov 22 2008, 09:53 PM
CliffBraun   Is a super trapp the same thing found on most tun...   Nov 22 2008, 09:59 PM
Chris Hamilton   Is a super trapp the same thing found on most tun...   Nov 22 2008, 10:40 PM
r_towle   I had a first generation Foley type header on a ra...   Nov 23 2008, 12:21 PM
turnaround89   I like the sound of the supertrapp, 1.) does the d...   Nov 23 2008, 12:44 PM
Chris Hamilton   I like the sound of the supertrapp, 1.) does the ...   Nov 23 2008, 01:27 PM
turnaround89   I been doing some reading about designing headers ...   Nov 23 2008, 05:17 PM
r_towle   Those are the 75/76 stub pipes that attach to the ...   Nov 23 2008, 06:12 PM
r_towle   Here is Paragon products complete system. This is ...   Nov 23 2008, 06:17 PM
LarryR   Here is Paragon products complete system. This is...   Nov 23 2008, 06:28 PM
r_towle   This is the Tangerine Racing (CFR) Chris Foley hea...   Nov 23 2008, 06:26 PM
r_towle   Now, The primaries are all bent all over the place...   Nov 23 2008, 06:30 PM
r_towle   Finally, here are the Tangerine racing (CFR) Chris...   Nov 23 2008, 06:36 PM
LarryR   That tangerine system is pretty sweet. However, ho...   Nov 23 2008, 06:46 PM
Joe Ricard   I bought my Tangerine back when I had a hopped up ...   Nov 23 2008, 07:11 PM
LarryR   I bought my Tangerine back when I had a hopped up...   Nov 23 2008, 07:30 PM
Joe Ricard   I bought my Tangerine back when I had a hopped u...   Nov 25 2008, 10:00 AM
LarryR   Had SSI and Bursch prior to Tangerine. oh heck y...   Nov 25 2008, 11:01 PM
turnaround89   Ok, now i got it, however i was also reading about...   Nov 23 2008, 10:40 PM
Racer Chris   Should i make my exhaust around the idea of makin...   Nov 24 2008, 02:57 PM
turnaround89   Alright, that makes sense. Where is the easiest p...   Nov 24 2008, 05:41 PM
biggy72   I like using spd exhaust. They are relatively inex...   Nov 24 2008, 11:35 PM
DTMLGND   Here is Paragon products complete system. This is...   Oct 17 2018, 02:01 PM
VaccaRabite   I have this on my new acquisition! :D I am ex...   Oct 17 2018, 06:22 PM
porschetub   Really if people look @ whats for sale they tend t...   Oct 18 2018, 12:10 AM
914GTSTI   If you can weld you can build a system. This is no...   Oct 18 2018, 09:13 PM
falcor75   I'm going to be trying to do my own system in ...   Oct 18 2018, 10:37 PM
914GTSTI   So get to work . Here is another system. http://...   Oct 18 2018, 11:02 PM
- Lo-Fi Version Time is now: 6th July 2025 - 10:34 PM
