Manual Fuel pump switch, and tips |
ONTHEGRIND |
Nov 22 2008, 01:20 PM
Member Group: Members Posts: 286 Joined: 10-November 08 From: California Member No.: 9,738 Region Association: None |
so I am installing a new bosch fuel pump for my factory fuel injection system.. Where my factory fuel pump used to one in the stock location, one of the mounting tabs is gone from a little bit of rust, so I am moving it to the firewall. And mounting it with sheet metal screws.. Any body have a manual fuel pump switch wired up so if that relay crap decides not to work I can just flip it on with a switch.. where do you have it mounted and how do you have it wired up ?
Thanks |
markb |
Nov 23 2008, 10:38 PM
914less :( Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California |
If the fuel lines were as bad as you say, you need to pull the tank & replace the lines there.
Lo-Fi Version | Time is now: 2nd June 2024 - 11:19 PM |
