Front BMW brakes locking front wheels all the time, why...please guys can i have your advice? |
budman5201 |
Nov 13 2008, 09:07 PM
Senior Member Group: Members Posts: 595 Joined: 1-April 07 From: tempe, az Member No.: 7,635 |
I recently bought new rear calipers, redid the front BMW brakes up front and installed HAWK race pads up front. The braking has significantly improved! YES! but now i have one dilema......The front brakes lock up EASILY and the rears never at all..........I wish i could make all them lock up in emergency situations or at least more Braking in the rear.
Did i just significantly make the front brakes better by installing new race pads and BMW brakes? Can i adjust anything with the stock rear system to get more pressure to the back so i dont lock up the front VERY EASILY??? thanks guys i appreciate your help..... Stock 1.7 liter GOING SUBARU 2.5 200 hp N/A soon!! Trying to make everything else PERFECT before i get my third Subaru done.....The braking was lacking on my last conversion...... thanks! Attached image(s) |
Eric_Shea |
Nov 22 2008, 05:22 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
QUOTE Eric, you mentioned the increase in pad area. My understanding is that the fundamental contributor is the increase in piston area. Am I wrong? Can you comment further? Both but, I'd say the pad area is causing the fronts to lock. Front pistons are 48mm which has thrown things off a bit as well which is why I recommend the 19mm MC. Chris... curious as to why you mismatched the pads. Glad you're stopping better. |
budman5201 |
Nov 24 2008, 01:28 AM
QUOTE Eric, you mentioned the increase in pad area. My understanding is that the fundamental contributor is the increase in piston area. Am I wrong? Can you comment further? Both but, I'd say the pad area is causing the fronts to lock. Front pistons are 48mm which has thrown things off a bit as well which is why I recommend the 19mm MC. Chris... curious as to why you mismatched the pads. Glad you're stopping better. i tried my best to find rear Hawks brand for the back, but couldnt locate a reseller so i chose the next best i though...portofields (the oranges is the one they sent me) Wouldnt a 19mm MC increase my foot pressure needed for the same pressure to the pads? |
Lo-Fi Version | Time is now: 2nd June 2024 - 08:43 PM |
