djet fuel pump problems... |
biggy72 |
Nov 29 2008, 07:21 PM
Member Group: Members Posts: 209 Joined: 14-January 06 From: Olympia, WA Member No.: 5,418 Region Association: Pacific Northwest |
Do djet fuel pumps ever have the fuel pump portion go bad and not the motor portion? Mine is pumping more fuel out the return port than it is out the high pressure port. I pulled it apart and everything looks to be ok, but maybe it's just worn out. I have the pump out of the car and I was bench testing it so I'm sure it's not just incorrectly plumbed or wired.
I'd like to put a new pump under the gas tank, but I would need to run new fuel lines to take the pressure to do that and I was just hoping to get it up and running to make sure everything is working ok before I jumped into a project like that. |
biggy72 |
Dec 1 2008, 10:27 PM
In another post someone said something about buying prebent fuel lines for the tunnel. Where can you get them at, and if I were to make them myself what sort of flare should I use on the ends to make sure the high pressure rubber lines stay on?
Lo-Fi Version | Time is now: 13th June 2024 - 03:28 AM |
