> Steering wheel slop on a /6
Lavanaut
post Oct 29 2008, 05:04 PM
Hungry Mind : Thirsty Gullet
I saw a thread recently where someone reported experiencing steering wheel slop in their 4-cylinder car. The quick fix there was a $13 'shim'. Naturally as I researched the topic more I came to find that on a /6 the only fix is to replace the $200+ upper steering column bearing. (IMG:style_emoticons/default/blink.gif) A little more research and I found out that if the 'pressure spring' between the steering wheel and bearing is missing you'll experience slop as well. Please let that be it, I hoped...
So I pulled my wheel off and here's what I saw. Just to be sure that I'm clear on what I'm seeing here, it looks to me like there is no spring AND no bearing?! (IMG:style_emoticons/default/WTF.gif) That 'lip' at the bottom of the splines is part of the steering shaft.
Anyone here familiar with this?
Thanks
post Dec 4 2008, 07:08 PM
Resident German
if you can wait a day, i can take some pix tomorrow ...
There's a clip that goes over the shaft on the hub. The spring goes onto that clip. Then both slide into the bearing on the column providing a schnugg fit ...
(IMG:style_emoticons/default/shades.gif) Andy
Lavanaut   Steering wheel slop on a /6   Oct 29 2008, 05:04 PM
r_towle   looks like you are missing the bearing and c-clip....   Oct 29 2008, 05:16 PM
sixnotfour   there is a ring that should lift out ( magnet) and...   Oct 29 2008, 05:19 PM
Lavanaut   Ahhhh...so the bearing is in there! I was thi...   Oct 29 2008, 06:16 PM
JWest   Ahhhh...so the bearing is in there! I was th...   Oct 30 2008, 09:43 AM
Gint   Please do...   Oct 29 2008, 09:47 PM
914Sixer   Replace the spring and upper spring clip. Upper s...   Oct 30 2008, 09:14 AM
Lavanaut   Replace the spring and upper spring clip. Upper ...   Oct 30 2008, 12:22 PM
Lavanaut   Replace the spring and upper spring clip. Upper ...   Oct 30 2008, 12:14 PM
914Sixer   Yes, that is the support ring I was talking about....   Oct 30 2008, 01:26 PM
sixnotfour   It apperars his ring is in place . Here is the sp...   Oct 30 2008, 03:55 PM
Lavanaut   I put a magnet on what I think is the bearing jack...   Oct 30 2008, 04:02 PM
Lavanaut   Got the spring from Sierra Madre (a while ago, but...   Dec 4 2008, 06:02 PM
Vacca Rabite   I'm going to order the clip now and when it a...   Dec 4 2008, 06:17 PM
SirAndy   if you can wait a day, i can take some pix tomorro...   Dec 4 2008, 07:08 PM
sixnotfour   wow , That is a great deal. Here is pictures of -...   Dec 4 2008, 07:47 PM
Cap'n Krusty   $200 bearing? List price is around 20 bucks....   Dec 4 2008, 08:35 PM
Lavanaut   Well, it [b]IS a steering wheel thread. Ah ah ah...   Dec 5 2008, 01:11 PM
sixnotfour   The wheel needs to go into the bearing , your shaf...   Dec 4 2008, 08:39 PM
Lavanaut   Finally got my hands on the clip. $49 after ...   Jan 6 2009, 12:56 PM
Lavanaut   Sooooo after this much anticipation I couldn't...   Jan 6 2009, 01:23 PM
SirAndy   That reminds me, wasn't i supposed to take a c...   Jan 6 2009, 01:43 PM
Lavanaut   Busy time of the year, I figured those pictures ju...   Jan 6 2009, 01:47 PM
Gint   Right on. How about listing the sources for the ...   Jan 6 2009, 07:47 PM
Lavanaut   Mike, check the Stoddard link in post #8 of this t...   Jan 6 2009, 10:23 PM
Gint   Thanks Reid!   Jan 6 2009, 10:54 PM
John   I take it that this part is the same one that the ...   Mar 6 2011, 10:55 PM
Lavanaut   Hi John, This thread is specifically in relation...   Mar 6 2011, 11:00 PM
John   Hi John, This thread is specifically in relatio...   Mar 6 2011, 11:29 PM
Vacca Rabite   So the six uses a different steering bushing then ...   Mar 7 2011, 07:49 AM
John   So the six uses a different steering bushing then...   Mar 8 2011, 12:27 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 09:42 AM
