Yay! I have a compressor, Now with 100% less evil images |
CliffBraun |
Dec 7 2008, 12:50 AM
Member Group: Members Posts: 252 Joined: 26-April 06 From: San Luis Obispo,ca Member No.: 5,933 Region Association: None |
A friend of mine called me about an old craftsman compressor on CL for $30 earlier today. Needless to say I was at the guy's house before I got off the phone. It had oil that may or may not have ever been changed (certainly was very dirty), and a small leak in one of the fittings.
Mysteriously at some point the fitting reseated itself properly and now there's a TINY leak on either side of the water trap. I now have a 1HP, oiled compressor to drive the air tools I bought and I paid only $30. I'm a very happy 914 owner right now. (IMG:http://lolinter.net/fail/Compressor/scaled.IMG_2015.JPG) Clicky pop image now. |
CliffBraun |
Dec 8 2008, 02:05 AM
Ow, my ears. I just decided it was a good time to take a compression tester and see how high the thing can go, the gauges read up to like 200 PSI. I screwed with the relay setup a bit until I figured out how it worked, adjusted it to off at some unknown high quantity. Turns out the dump valve gets stuck open at 140 PSI and won't close til about 100 without being pushed back in.
I've calibrated the regulator to 90PSI which is the max recommended for my air tools, but I figure tank pressure should be as high as I can get it to increase initial longevity. Any suggestions as to how to make the relief valve seal for longer? Am I risking blowing up the tank? Gauges read to 200 PSI and are high by about 5%. Relief sticks open at like 115 actual pressure. |
Lo-Fi Version | Time is now: 16th June 2024 - 02:29 AM |
