| johannes |
Dec 16 2008, 06:04 PM
Club Porsche 914 France member since 2005 ![]() ![]() ![]() ![]() Group: Members Posts: 3,092 Joined: 13-January 06 From: France Member No.: 5,409 Region Association: France |
As the 914 was supposed to be cheaper than the 911 why did they go the pop up way ?
I was told, the 914 had to feature popup headlights because the US regulation mandated a minimum height for the headlights ... I made some searches on the Internet and found this excellent wiki... http://en.wikipedia.org/wiki/Headlamp ... They tell a lot about the 7' round, shaped, sealed lamps ... but there is no information about height. Can you light me ? (IMG:style_emoticons/default/biggrin.gif) |
| Eric_Shea |
Dec 17 2008, 08:29 PM
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Man... now that I'm home and have the time to read through this stuff, it's simply amazing. GREAT job Chris (if you're out there)!!
Back on target, if the mirrors coming off can give you a little over 1/2 hp, imagine what a couple of pop up lights can do smack dab in the middle of the air stream. I would imagine that helps answer the original question why pop up headlights. I would say it's a bit of a design feature to clean out the lines and it really helps in the CD arena. I'm amazed at the dye tests with the top and windows up. The computer models prove it out as well. The 914 does DAMN good for a late 60's design. LOOK WHAT HAPPENS TO THE DOWN FORCE WITH THE WINDOWS AND TOP OFF!!! (computer models and the dye test) Wow! That's more like what I see with a standard 911 shape, spoiled air right over the rear wheels, hence the need for a tail on a 911 to force the spoiled air behind the vehicle. - Stock has 28lbs. of down force (Newton value converted) - Top off and windows down has -6.67lbs. (better know as lift as it spoils the rear air-flow over the decklid) The best you could probably get with a stripped down (no windshield) race version might be around 50lbs. of additional downforce so we're not talking about great advantages either way. I'm suprised at how well a stock car works. The main thing I'm getting from this is; the worst thing you could do is add front and rear spoilers (well... that and take your top off). Look at example #13; the delta on the drag is 64.2093 newton, the lift is now 5.26lbs. greater and the loss of hp is 2.084. This basically proves that "every" aerodynamic gadget we have available at our disposal does more harm than good. Big wings simply add more drag, more lift and less hp. I'm happy with my stock GT look I guess. (IMG:style_emoticons/default/wink.gif) |
| ClayPerrine |
Dec 18 2008, 02:06 PM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,542 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
The main thing I'm getting from this is; the worst thing you could do is add front and rear spoilers (well... that and take your top off). Look at example #13; the delta on the drag is 64.2093 newton, the lift is now 5.26lbs. greater and the loss of hp is 2.084. This basically proves that "every" aerodynamic gadget we have available at our disposal does more harm than good. Big wings simply add more drag, more lift and less hp. I'm happy with my stock GT look I guess. (IMG:style_emoticons/default/wink.gif) Actually adding a front air dam (spoiler) will help the stability of a 914. While slicker and faster without it, the front of a 914 will lift at high speed without one. This makes the car unstable. So you won't be able to drive as fast. The same thing was discovered with the 917 when John Weir took over the Gulf Porsche team. Porsche wanted to concentrate on the long tail, but the short tail was way more stable after adding a few spoilers, and was able to make better lap times because it didn't have to slow down as far for the turns. |
| r_towle |
Dec 18 2008, 03:23 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
The main thing I'm getting from this is; the worst thing you could do is add front and rear spoilers (well... that and take your top off). Look at example #13; the delta on the drag is 64.2093 newton, the lift is now 5.26lbs. greater and the loss of hp is 2.084. This basically proves that "every" aerodynamic gadget we have available at our disposal does more harm than good. Big wings simply add more drag, more lift and less hp. I'm happy with my stock GT look I guess. (IMG:style_emoticons/default/wink.gif) Actually adding a front air dam (spoiler) will help the stability of a 914. While slicker and faster without it, the front of a 914 will lift at high speed without one. This makes the car unstable. So you won't be able to drive as fast. The same thing was discovered with the 917 when John Weir took over the Gulf Porsche team. Porsche wanted to concentrate on the long tail, but the short tail was way more stable after adding a few spoilers, and was able to make better lap times because it didn't have to slow down as far for the turns. Do spoilers really help in an autox? If we accept that 65 mph is the fastest you can go, does aerodynamics really come into play on the front end? Rich |
johannes Why pop up headlights ? Dec 16 2008, 06:04 PM
charliew Same way with the fiero. It's a pretty expensi... Dec 16 2008, 06:38 PM
mikez Try looking in the State Motor Vehicle Regs. Ther... Dec 16 2008, 06:43 PM
r_towle Same issue with emmissions and the 75/76 bumper up... Dec 16 2008, 07:28 PM
jimkelly aerodynamic drag - at least when the sun is up you... Dec 16 2008, 08:33 PM
6freak
aerodynamic drag - at least when the sun is up yo... Dec 17 2008, 07:56 AM
johannes
aerodynamic drag - at least when the sun is up y... Dec 17 2008, 08:11 AM
6freak
[quote name='6freak' post='1112392' date='Dec 17 ... Dec 17 2008, 08:19 AM
effutuo101 I got a ticket in California when I was a kid. the... Dec 16 2008, 09:33 PM
johannes I read somewere:
AK, AL, AR, AZ, DC, DE, FL, GA,... Dec 17 2008, 03:19 AM
Root_Werks
I read somewere:
AK, AL, AR, AZ, DC, DE, FL, GA... Dec 17 2008, 09:23 AM
orthobiz
I read somewere:
AK, AL, AR, AZ, DC, DE, FL, GA... Dec 17 2008, 04:16 PM
johannes
I read somewere:
AK, AL, AR, AZ, DC, DE, FL, G... Dec 17 2008, 05:30 PM
neo914-6
[quote name='orthobiz' post='1112572' date='Dec 1... Dec 17 2008, 05:48 PM
URY914 The 914 cd rating was just a hair lower than a 911... Dec 17 2008, 08:04 AM
Eric_Shea
Paul, I'm confused. I would have though ... Dec 17 2008, 08:31 AM
URY914
Paul, I'm confused. I would have though ... Dec 17 2008, 10:19 AM
6freak
Paul, I'm confused. I would have though ... Dec 17 2008, 01:42 PM
ericread
[quote name='URY914' post='1112441' date='Dec 17 ... Dec 17 2008, 01:55 PM
Todd Enlund
I respectfully disagree.it breaks up the drag sur... Dec 17 2008, 02:21 PM
roadster fan
This is true, but the principle is different. Th... Dec 17 2008, 02:33 PM
johannes I don't think the CX of the 914 is that good b... Dec 17 2008, 09:23 AM
neo914-6
I don't think the CX of the 914 is that good ... Dec 17 2008, 12:41 PM
Demick You're all wrong. The real purpose of the pop... Dec 17 2008, 09:36 AM
highways
You're all wrong. The real purpose of the po... Dec 17 2008, 12:59 PM
yellow914 I know this might be going O.T. a bit...but given ... Dec 17 2008, 01:26 PM
blitZ Just get some Euro front turn signals and put some... Dec 17 2008, 01:45 PM
johannes In the sixties the "flush" headlights we... Dec 17 2008, 01:53 PM
biggy72
I respectfully disagree.it breaks up the drag su... Dec 17 2008, 02:46 PM
Solo914
[quote name='Todd Enlund' post='1112529' date='De... Dec 17 2008, 02:57 PM
Solo914 Fun stuff.
http://www.eng-tips.com/viewthread.cf... Dec 17 2008, 03:04 PM
Todd Enlund
I was thinking about this last night, but why are... Dec 17 2008, 03:03 PM
Jeff Bowlsby Someone say '914' and 'Bonneville... Dec 17 2008, 03:20 PM
biggy72 I found another picture of a red 914 at bonneville... Dec 17 2008, 03:30 PM
bandjoey There was a show on Myth Busters a year ago about ... Dec 17 2008, 03:33 PM
Spoke No dimples on this vehicle & lots of thrust. Dec 17 2008, 03:54 PM
RiqueMar Off topic from Aerodynamics, but what about theft ... Dec 17 2008, 04:09 PM
6freak
... Dec 17 2008, 05:11 PM
biggy72 http://en.wikipedia.org/wiki/Vortex_generator Dec 17 2008, 04:23 PM
Eric_Shea
Grumpy today aren't we?
Seriously, wouldn... Dec 17 2008, 04:36 PM
URY914 E, I wasn't being mean, just being a smart ass... Dec 17 2008, 04:50 PM
Eric_Shea I know... I'm just :poke: ing at ya.
The prob... Dec 17 2008, 05:02 PM
ericread You wanted information about 914 aerodynamics? Yo... Dec 17 2008, 05:34 PM
6freak
You wanted information about 914 aerodynamics? Y... Dec 17 2008, 06:14 PM
ericread
[quote name='ericread' post='1112607' date='Dec 1... Dec 17 2008, 07:19 PM
6freak
[quote name='ericread' post='1112607' date='Dec ... Dec 18 2008, 10:02 AM
Eric_Shea
Fun link. Paul, that looks like your car on tha... Dec 17 2008, 06:08 PM
6freak
[quote name='ClayPerrine' post='1112833' date='De... Dec 18 2008, 04:13 PM
scrz914 Dimples on a golf ball are for spin control. Back ... Dec 17 2008, 08:54 PM
Phoenix 914-6GT See Mike, my big air dam didn't help me at all... Dec 18 2008, 01:07 PM
6freak
See Mike, my big air dam didn't help me at al... Dec 18 2008, 03:58 PM
Pnambic I saw a show on TV earlier in the year that was re... Dec 18 2008, 01:54 PM
Phoenix 914-6GT Well who wants their car to handle properly :confu... Dec 18 2008, 02:10 PM
URY914 Wyer Dec 18 2008, 02:12 PM
Pnambic Hmmm....so if I'm racing and I want a little e... Dec 18 2008, 02:25 PM
6freak
Hmmm....so if I'm racing and I want a little ... Dec 18 2008, 04:08 PM
URY914 Unlatch the roof and push up the back of it too. Dec 18 2008, 02:53 PM
URY914 Plan and simple: Spoilers don't work when you ... Dec 18 2008, 04:26 PM
Al Meredith When my Son was running EProduction in a 914 he lo... Dec 18 2008, 04:58 PM
6freak
When my Son was running EProduction in a 914 he l... Dec 18 2008, 05:18 PM
Eric_Shea
You need to read some more... :lol:
He... Dec 18 2008, 05:55 PM
Phoenix 914-6GT
:co... Dec 18 2008, 07:13 PM
Eric_Shea
I'm pretty sure a splitter, wing or an air d... Dec 18 2008, 08:12 PM
Phoenix 914-6GT I didn't know we were only talking about autoc... Dec 18 2008, 09:00 PM
Solo914 Eric,
You are right, at autcross speeds, MOST wi... Dec 18 2008, 09:23 PM
Eric_Shea
OK... other than Talladaga and the high banks at... Dec 18 2008, 09:21 PM
Phoenix 914-6GT
OK... other than Talladaga and the high banks a... Dec 18 2008, 10:08 PM
Eric_Shea What's that thing? :D
(nice looking car Kyle,... Dec 18 2008, 09:40 PM
Solo914
(nice looking car Kyle... Dec 18 2008, 09:48 PM
Eric_Shea Someone misplaced their sense of humor. Check out... Dec 18 2008, 11:11 PM
Phoenix 914-6GT eh... it's these kids I tell you. They are dri... Dec 18 2008, 11:21 PM
biggy72 I know it isn't a 914, but it also only hits a... Dec 19 2008, 12:05 AM
URY914 Front spoilers reduce the amount of air that gets ... Dec 19 2008, 06:29 AM
J P Stein
I'm gettin' as grumpy as JP....
Bout ... Dec 19 2008, 08:41 AM
6freak
Bout... Dec 19 2008, 09:21 AM
6freak
Front spoilers reduce the amount of air that gets... Dec 19 2008, 09:13 AM
J P Stein OK, now 914 related....we were parked next to the ... Dec 19 2008, 08:55 AM
J P Stein That's *due respect* & you misspelt my nam... Dec 19 2008, 09:32 AM
6freak
That's *due respect* & you misspelt my na... Dec 19 2008, 12:05 PM
DNHunt This is kind of a change of subject but, in the la... Dec 19 2008, 10:01 AM
Pnambic
This is kind of a change of subject but, in the l... Dec 19 2008, 10:21 AM
chris914
Any of you guys got a windtunnel?
Yes. :D Dec 20 2008, 12:58 AM
URY914 Back in the day when my car still had headlights a... Dec 19 2008, 10:34 AM
Phoenix 914-6GT Mike, I am going to use Ury's quote for you si... Dec 19 2008, 10:41 AM
Jeff Bowlsby :D Dec 20 2008, 09:53 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 09:23 AM |
