Refinishing a fiberglass top? |
KaptKaos |
Dec 26 2008, 04:13 PM
Family Group: Members Posts: 4,009 Joined: 23-April 03 From: Near Wausau Member No.: 607 Region Association: Upper MidWest |
I have heard folks say that to refinish a top so it's smooth, you need to apply a gel coat to it and sand it smooth.
Anyone have specific instructions on this? What supplies do I need and how best to do it? TIA |
southernmost914 |
Dec 26 2008, 06:03 PM
KEY WEST/HAVANA Tunnel Authority Group: Members Posts: 338 Joined: 16-October 07 From: Key West/ St. Augie, Fl USA Member No.: 8,234 Region Association: South East States |
Scotty, (IMG:style_emoticons/default/pray.gif) I have seen your work and you are" the man". After working with fiberglass for 20 years I can tell you that bare fiberglass needs a barrier coat or it will asorb water and delaminate.( gel coat or a non water asorbing filler such as All-metal )Paint by it self will not do it. The West -System stuff that I mentioned can be sprayed or mixed to a bondo like thickness, is a barrier coat, can be sanded like auto filler, will not crack or delaminate, and is made for bonding with and faring fiberglass. www.westsystem.com (IMG:style_emoticons/default/biggrin.gif)
Steve |
scotty b |
Dec 26 2008, 06:29 PM
rust free you say ? Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None |
Scotty, (IMG:style_emoticons/default/pray.gif) I have seen your work and you are" the man". After working with fiberglass for 20 years I can tell you that bare fiberglass needs a barrier coat or it will asorb water and delaminate.( gel coat or a non water asorbing filler such as All-metal )Paint by it self will not do it. The West -System stuff that I mentioned can be sprayed or mixed to a bondo like thickness, is a barrier coat, can be sanded like auto filler, will not crack or delaminate, and is made for bonding with and faring fiberglass. www.westsystem.com (IMG:style_emoticons/default/biggrin.gif) Steve Nuff said (IMG:style_emoticons/default/biggrin.gif) I've done some minor glass work on cars but if it needs a gel coat so be it. I've always assumed that the primer/sealer I use was enough. Should I consider using actual gel coat on glass cars from now on ? Normally when I strip them I can stay within the original gel coat but on some like that Ferrari kit where I had to repair I counted on the bondo to be my isolation coat. |
southernmost914 |
Dec 26 2008, 06:39 PM
Scotty, (IMG:style_emoticons/default/pray.gif) I have seen your work and you are" the man". After working with fiberglass for 20 years I can tell you that bare fiberglass needs a barrier coat or it will asorb water and delaminate.( gel coat or a non water asorbing filler such as All-metal )Paint by it self will not do it. The West -System stuff that I mentioned can be sprayed or mixed to a bondo like thickness, is a barrier coat, can be sanded like auto filler, will not crack or delaminate, and is made for bonding with and faring fiberglass. www.westsystem.com (IMG:style_emoticons/default/biggrin.gif) Steve Nuff said (IMG:style_emoticons/default/biggrin.gif) I've done some minor glass work on cars but if it needs a gel coat so be it. I've always assumed that the primer/sealer I use was enough. Should I consider using actual gel coat on glass cars from now on ? Normally when I strip them I can stay within the original gel coat but on some like that Ferrari kit where I had to repair I counted on the bondo to be my isolation coat. No, I don't think you need to use gel coat. If the primer/sealer being used is a true water barrier coat thats cool, or if the filler is not moisture asorbing and a barrier that's cool also. Just saying westsystem is made to bond ,strengthen,fill and seal glass. (IMG:style_emoticons/default/beerchug.gif) Steve |
Lo-Fi Version | Time is now: 10th June 2024 - 11:42 PM |
