> Ran out of Gas sh@# f%$%, Now it won't start......
ldino21
post Jan 20 2004, 12:17 PM
Driving the car home last night with the gas gauge reading 1/2 full my car all of a sudden sputtered and stalled like it ran out of gas!! I went to the gas station got a gallon of gas and it still would not start.
Is there anything special I should know, to try to get this to start? could I have blown a fuel injector?? Is maybe a gallon not enough in the tank and I need to add a couple more??
Any suggestions would help!!
By the way its a 1973 1.7 with D-Jet injection
ArtechnikA
post Jan 20 2004, 01:40 PM
rich herzog
QUOTE(ldino21 @ Jan 20 2004, 11:31 AM)
I am hoping not to have to do that again!!!
you gotta let us help you by providing more information.
how much gas is in the tank, REALLY ?
when you turn the key to the 'on' position, do you hear the fuel pump run for a moment ?
(if no, find out why your fuel pump is not running. CHECK THE FUSES - all of them)
pull a spark plug. if there is fuel pressure but no spark the plug will probably be wet with gas; find and fix the ignition problem.
all further speculation is pointless until we know what kind of problem you're dealing with. it's probably something simple but right now, it could still be anything ...
ldino21   Ran out of Gas sh@# f%$%   Jan 20 2004, 12:17 PM
Mueller   You might have to trick the fuel pump into running...   Jan 20 2004, 12:22 PM
ArtechnikA   <...   Jan 20 2004, 12:27 PM
!   Ether/quick start....if that doesn't do it.......   Jan 20 2004, 12:28 PM
SirAndy   :agree: all the above. also, IF you ran out of g...   Jan 20 2004, 12:51 PM
Seaside6   I thought mine had run out of gas and I added 2 ga...   Jan 20 2004, 12:56 PM
ldino21   After adding the gas, the motor cranked and cranke...   Jan 20 2004, 01:31 PM
vsg914   Indio, Did you hear the fuel pump? Could you smell...   Jan 20 2004, 01:39 PM
ArtechnikA   <...   Jan 20 2004, 01:40 PM
ldino21   Yes the fuel pump runs every time, no problem. I w...   Jan 20 2004, 01:49 PM
mike_the_man   The same thing used to happen to my Volvo all the ...   Jan 20 2004, 01:56 PM
jkeyzer   Open the fuel cap and look inside with a flashligh...   Jan 20 2004, 06:55 PM
736conver   It does sound like a spark issue.   Jan 20 2004, 07:00 PM
Bleyseng   Don't use a match to look down into the gas ta...   Jan 20 2004, 07:01 PM
redshift   The early Haynes says to use a torch. M   Jan 20 2004, 07:21 PM
ejm   ...   Jan 20 2004, 08:11 PM
  Jan 20 2004, 08:17 PM
Gint
  Jan 20 2004, 10:47 PM
Bruce Allert   I used a match to see if my battery was low! :...   Jan 20 2004, 10:49 PM
Curvie Roadlover   <...   Jan 21 2004, 09:36 PM
Gint   Congrats! :trophy: :beer1: You're loo...   Jan 21 2004, 10:03 PM
ArtechnikA   stuff like that has happened to all of us. or will...   Jan 22 2004, 06:44 AM
Bruce Allert   <...   Jan 22 2004, 08:10 AM
vsg914   Indio, make sure the coil is properly secured. The...   Jan 22 2004, 08:16 AM
Pnambic   <...   Jan 22 2004, 08:26 AM
mike_the_man   Same sort of thing happened to me too. Was blasti...   Jan 22 2004, 09:52 AM
- Lo-Fi Version Time is now: 16th June 2024 - 08:07 PM
