| kkid |
Jan 6 2009, 12:47 AM
Member ![]() ![]() Group: Members Posts: 362 Joined: 18-December 07 From: Oakland, CA Member No.: 8,483 Region Association: Northern California |
I've been skeptical if there is some vacuum leak since the warm idle still goes up and down about ±50~100.
So I covered the air inlet on the air cleaner housing completely but the engine was still running as if nothing happened. Does this mean there is a huge air leak or is it designed to breath the air from somewhere else???? Thanks in advance (IMG:style_emoticons/default/pray.gif) |
| ericread |
Jan 7 2009, 11:27 PM
The Viper Blue 914 ![]() ![]() ![]() ![]() Group: Members Posts: 2,177 Joined: 7-December 07 From: Irvine, CA (The OC) Member No.: 8,432 Region Association: Southern California |
It doesn't seem to be a TB/Plenum issue. Work the issues above and let us know what you find... Eric |
kkid Vacuum Leak? Jan 6 2009, 12:47 AM
Dave_Darling Huge air leak from somewhere. All the air getting... Jan 6 2009, 01:47 AM
kkid
Huge air leak from somewhere. All the air gettin... Jan 12 2009, 01:49 AM
kkid Thanks DD!
But I don't see any other hole... Jan 6 2009, 02:05 AM
SLITS 1.) Expansion hoses on the plenum to runners
2.)... Jan 6 2009, 07:44 AM
kkid Hello Ron, Thanks for the advise. I'll follow ... Jan 6 2009, 07:35 PM
ericread How about removing the air cleaner and closing off... Jan 6 2009, 07:40 PM
kkid Yeah, you're right, Eric.
The engine died in... Jan 7 2009, 01:22 AM
SLITS All of the items you mentioned are pre-TB / plenum... Jan 7 2009, 08:03 AM
Spoke Find vacuum leaks fast with carb cleaner. Spray on... Jan 12 2009, 08:02 AM
kkid I have been ignoring this issue since the car runs... May 15 2009, 12:07 AM
ConeDodger Did you look at the bottom of the plenum? These th... May 15 2009, 09:09 AM
RobW Plenums get tweeked when you don't have the ac... May 15 2009, 10:18 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 06:21 PM |
