tap sizes, compression fittings |
Randal |
Dec 27 2008, 07:37 PM
Advanced Member Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 |
This is somewhat racing related (IMG:style_emoticons/default/smash.gif) I bought a new air pump for my old compressor but have to build a new manifold and re-plumb my air connections. Need some help. I'm using two lines, one is 1/2 steel and the other 1/4 copper. I'm using compression fittings on both. What tap size do I use on the 1/2" compression fitting to tap into my new manifold? On one side the compression fitting will be connected to the 1/2" pipe, the other side (minus the compression fitting) will be threaded into my new manifold. Both sides of the compression fitting are the same. Likewise for the 1/4" compression fitting, i.e., what tap size? Thanks. |
J P Stein |
Jan 10 2009, 05:01 PM
Irrelevant old fart Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None |
The car/trailer snuggles up pretty well behind my truck. I have a winch to load/unload the car and such a gizmo would prolly just get in the way. If I didn't have the canopy it might be worth the hassle. My truck is gonna get crappy milage....unless the hand of God pushes.
Attached thumbnail(s) |
0396 |
Jan 11 2009, 12:25 AM
Advanced Member Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California |
The car/trailer snuggles up pretty well behind my truck. I have a winch to load/unload the car and such a gizmo would prolly just get in the way. If I didn't have the canopy it might be worth the hassle. My truck is gonna get crappy milage....unless the hand of God pushes. Question, why did you 'tie' the rears straight back- instead of an x |
J P Stein |
Jan 11 2009, 08:17 AM
The car/trailer snuggles up pretty well behind my truck. I have a winch to load/unload the car and such a gizmo would prolly just get in the way. If I didn't have the canopy it might be worth the hassle. My truck is gonna get crappy milage....unless the hand of God pushes. Question, why did you 'tie' the rears straight back- instead of an x It's actually a one strap V....attached to each wheel and center point on the trailer then pulled up snug with the racheting straps (which angle inward) & the winch. With the winch cable pulled up snug to the wheel chocks there is NO fore & aft movement. I've also tried it with the winch cable detached & was able to feel the car move around while towing......didn't like that. Last year we prolly towed it 3500 miles. I really don't like the single axle trailer but make the effort to keep the bearings & tires in top notch shape.....and carry a spare..... hay, it was cheep. |
Lo-Fi Version | Time is now: 6th June 2024 - 07:51 PM |
