Carbon Fiber, Filler for the turn signal hole |
Randal |
Jan 15 2009, 04:39 PM
Advanced Member Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 |
Received a beautiful piece of 1mm CF sheet today which I going to use to block off the turn signal holes.
I was thinking it would look better to make a template that fit under the lip and then use the existing screw holes to attach the CF to the car. The problem I see is that attaching it from the top (using the same screw holes) is that you'd see the side of the CF, where it is cut. Maybe there is a nice (small) rubber bead at McMaster Carr that I could put around the CF so you wouldn't see where it is cut. So underneath or on top, what do you think would look better? |
Lo-Fi Version | Time is now: 3rd June 2024 - 03:11 AM |
