| JeffBowlsby |
Jan 16 2009, 07:59 PM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,222 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
Spotters guide: There are other differences, but here some basics to help you recognize them from a distance.
The factory valence has this part number molded proud into the inside center surface, aftermarket does not. The numbers are about 1/2 in high, near the bottom edge. The VW symbol is dead centered on the valence. This part is NLA. The inside surface is raw white plastic, not painted. The factory valence has 2 metal angled support braces and hardware, aftermarket does not. The orange valence in these photos is factory, the black one is aftermarket. There are several different aftermarket companies making these so called 'LE spoilers' and each one is different, this black one I show is only one of several styles. Look at the photos for differences in details and quality. I have not seen a believable aftermarket unit, but I would not think these would be hard to copy perfectly. Can anyone here mold these and repro an excellent copy? I bet there are some LE owners who would want good repros, only about 25% of the surviving LE cars still their have factory spoilers. Attached image(s)
| burton73 |
Jan 17 2009, 09:42 PM
Senior member, and old dude ![]() ![]() ![]() ![]() Group: Members Posts: 3,989 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California
Hi,
I have a factory LE spoiler on my 76 car that came from the factory with it. It had a small amount of damage on a corner so I bought a copy to put on till I get around to fixing it. The copy that you show is a good copy as copies go but it is a copy. My wife could not tell. As I have been in the plastic biz for 34 years and 3-d molding of polyesters as one of my specialties over the years I have thought on this. The factory part could have been cast under vacuum or pressure. When you close up a part that big the tooling starts to cost a lot compared to fiberglass layup tooling. The precision that you get is dead nuts on but cost a lot. Please excuse my spelling as am in Hong Kong now at the airport going to my factory in China to celebrate the New Year. I do not do this work now. I have done work before making special 2 part hard urethane foam material for rifiel stocks in closed molds made of filled urathane. You bolt the two parts of the mold after you wax it and pour the expanding foam material. If fills up the mold and builds pressure giving you a primo 3-d part. You just need to experiment on how much material to put in so you do not over fill it. Some foam expand 2 to 1, 3 to 1 so on. You need to Ck with the supplier. Bob |
| JeffBowlsby |
Jan 18 2009, 08:14 AM
Bob, this sounds like a great way to cast parts in detail. Is the product for the part the same as rigid polyurethane foam? If you used it for rifle stocks, it must be pretty durable.
Hi, I have a factory LE spoiler on my 76 car that came from the factory with it. It had a small amount of damage on a corner so I bought a copy to put on till I get around to fixing it. The copy that you show is a good copy as copies go but it is a copy. My wife could not tell. As I have been in the plastic biz for 34 years and 3-d molding of polyesters as one of my specialties over the years I have thought on this. The factory part could have been cast under vacuum or pressure. When you close up a part that big the tooling starts to cost a lot compared to fiberglass layup tooling. The precision that you get is dead nuts on but cost a lot. Please excuse my spelling as am in Hong Kong now at the airport going to my factory in China to celebrate the New Year. I do not do this work now. I have done work before making special 2 part hard urethane foam material for rifiel stocks in closed molds made of filled urathane. You bolt the two parts of the mold after you wax it and pour the expanding foam material. If fills up the mold and builds pressure giving you a primo 3-d part. You just need to experiment on how much material to put in so you do not over fill it. Some foam expand 2 to 1, 3 to 1 so on. You need to Ck with the supplier. Bob |
Jeff Bowlsby 914 Can Am front spoiler Jan 16 2009, 07:59 PM
Jeff Bowlsby Front corner view Jan 16 2009, 08:00 PM
Jeff Bowlsby Side view: Note the plumb vertical edge and parall... Jan 16 2009, 08:01 PM
Jeff Bowlsby Wheel well edge: Jan 16 2009, 08:02 PM
sww914 Are the factory originals molded plastic? All of t... Jan 16 2009, 08:25 PM
southernmost914
Are the factory originals molded plastic? All of ... Jan 16 2009, 08:47 PM
Jeff Bowlsby The originals are fairly thin, only about 1/16 - 3... Jan 16 2009, 08:52 PM
southernmost914 Oh, Grashopper I like your wings!
Steve Jan 16 2009, 08:58 PM
Jeff Bowlsby
Steve
Th... Jan 16 2009, 09:06 PM
championgt1
Steve
... Jan 16 2009, 09:14 PM
watsonrx13
I would be very interested.....
Jeff, thanks for... Jan 17 2009, 06:41 AM
rdauenhauer The one I have on my car is an OE piece and was or... Jan 17 2009, 11:10 AM
Gint The one I have on my car is an OE piece and was or... Jan 17 2009, 12:15 PM
Jeff Bowlsby It would be great to see the wheel well edge detai... Jan 17 2009, 04:25 PM
Jeff Bowlsby Thanks for posting about James' spoiler Rich. ... Jan 17 2009, 11:14 AM
Mark Henry I thought mine was A/M as it looks more like the b... Jan 17 2009, 12:03 PM
J P Stein Mine is aftermarket and used primarily as a cone r... Jan 17 2009, 12:09 PM
1970 Neun vierzehn This is an aftrmkt item manufactured and/or distri... Jan 17 2009, 10:35 PM
Jeff Bowlsby Ahhh, is this the same company? Jan 18 2009, 08:01 AM
1970 Neun vierzehn
Jeff, the spoi... Jan 19 2009, 08:52 PM
Jeff Bowlsby Here is the VPC version: Jan 18 2009, 08:07 AM
Johny Blackstain :shades: Jan 18 2009, 02:12 PM
RAB914
is yellow inside ther is original? Jan 18 2009, 03:33 PM
SirAndy There's one on german eBay right now ... :sha... Jan 18 2009, 03:45 PM
Gustl does anybody know if this front spoiler is the sam... Jan 18 2009, 04:15 PM
davep I you are talking about the 914/4 M471, then this ... Jan 19 2009, 03:40 PM
Gustl
I you are talking about the 914/4 M471, then this... Jan 19 2009, 11:20 PM
sixnotfour
made from abs about 3 mm thick, had end caps glue... Jan 19 2009, 06:39 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:14 PM |
