Carbs and fuel pump relay, my solution |
hcdmueller |
Feb 2 2009, 03:27 PM
????????????? Group: Members Posts: 542 Joined: 4-February 06 From: UK Member No.: 5,527 Region Association: England |
I am running carbs on my 2056 so I performed the simple mod as described by SirAndy in the Tech Articles. One thing I have noticed with my car is that my fuel pump runs continuously with the key switched on. The fuel pump is a rotary one that I bought from the Type4Store.
I didn't like that fact that my pump kept running so I took matters into my own hands. I modified a Bosch CIS fuel pump relay to work with my car. It needs a signal from the negative side of the coil to provide power to the fuel pump. So unless the engine is cranking or running it won't start up the pump. Nice to have the extra safety margin as well. The relays are easy to find in the junk yard. I only paid a couple dollars for 3 of them. Attached image(s) |
r_towle |
Feb 2 2009, 03:40 PM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Interesting idea.
What are you thinking for the long term storage/ first spring start? That would be when you have no fuel left in the bowls of the carbs...it all evaporated. That is what I like about the FI setup, on Djet anyways...I can turn the key to run three or five times to prime the system and then it starts on one crank...It seems alot nicer to the starter circuit to me. Rich |
Lo-Fi Version | Time is now: 1st June 2024 - 11:36 AM |
