> Daily driver mods?, Reliability and user-friendliness tips wanted
mbrown3039
post Feb 15 2009, 05:19 PM
After the consequential dust of my 2008 fiscal year has begun to settle, it looks like the Blue Bomber (1976 2.0) will need to be my daily driver for the forseeable future. So here's my question:
Assuming that it is factory stock (it is) and that I've done nothing to it (close enough to true), what mods would you make to it (sort of sticking a Subie in it, which I've considered) to make her a dependdable, safe daily driver?
BB needs to be reliable enough for daily driving to/from appointments (I'm in sales) and safe enough for me to feel fine about having my two-year old riding shotgun (i.e., I want her to start when I say so and stop when I need to). She won't do in the summer (no A/C) but other than that, what am I missing now?
Thanks, Mike
ericread
post Feb 15 2009, 07:58 PM
The Viper Blue 914
I've driven my 914 as a DD for about three years now. That means M-F about 30 miles each way and usually some entertaining trips on the weekend of around 125 miles.
#1. Make sure everything is as watertight as a 914 should be.
#2. Install a CHT. You can get a good probe, meter and extension wire for about $100, and it will really tell you what your engine is doing.
#3. I like the Pertronix unit.
#4. Religiously change your oil, oil filter and air filter.
#5. Make sure your suspension and brakes are in excellent working order.
#6. Plan to spend at least one weekend day per month looking for problems:
Check the alternator belt
Look for and correct oil leaks.
Make sure sure all your engine tin is in place and properly bolted down.
Inspect and lube your suspension (if appropriate).
Check the accelerator and clutch cables for tightness and wear.
Check your distributor parts for wear.
Check your pugs for gap/wear and color. Along with the CHT, they will tell you an awful lot about what your engine's doing.
Check your wheel bearings for excessive play.
Check your tire pressure.
On a quarterly basis check your CV joints and check the level of your transmission fluid. No need to change it, just check the levels.
My teener never lets me down (knock on wood). But I tend to spend the time necessary to see problems developing, rather than spending time reacting to problems .
Eric Read
mbrown3039
post Feb 15 2009, 08:09 PM
QUOTE(ericread @ Feb 15 2009, 05:58 PM) *
#2. Install a CHT. You can get a good probe, meter and extension wire for about $100, and it will really tell you what your engine is doing. Eric Read
Thanks -- just the kind of list I was looking for! As for the CHT, do you recommend a particular unit? Will it bolt into an existing hole or am I going to have to drill into the head to thread a new hole? Mike
(IMG:style_emoticons/default/sawzall-smiley.gif)
ericread
post Feb 15 2009, 08:38 PM
The Viper Blue 914
QUOTE(mbrown3039 @ Feb 15 2009, 06:09 PM) *
http://aircraftspruce.com/catalog/inpages/CHT_gauges2.php
The Micro-1000 CHT is from Aircraft Spruce, a company that provides aircooled aircraft engine parts. It comes as a circular gauge (which fits into an existing center console hole if you have one) or you can order it with the square aircraft meter face. They're local to SoCal (Corona) so I drove over and picked one up. The probe goes aroung the spark plug on cylinder-3, so no drilling/cutting is necessary. You'll need the probe, the meter and the extension wire.
Let me know if you need part numbers. spent just about $100 adn it installed in minutes. The biggest PIA is getting the wire through the center tunnel.
Eric
mbrown3039
post Feb 16 2009, 12:45 AM
QUOTE(ericread @ Feb 15 2009, 06:38 PM) *
The Micro-1000 CHT is from Aircraft Spruce, a company that provides aircooled aircraft engine parts...Let me know if you need part numbers.
Eric
Part numbers would be great, as I have questions about what I've read on the website and I'd rather hear it from someone with applicational experience. Thanks, Mike
ericread
post Feb 16 2009, 08:54 AM
The Viper Blue 914
QUOTE(mbrown3039 @ Feb 15 2009, 10:45 PM) *
Eric
Mike;
I'm at work today and I don't have the docs on my work computer. I'll upload the part numbers tonight.
Eric
mbrown3039
post Feb 16 2009, 12:45 PM
QUOTE(ericread @ Feb 16 2009, 06:54 AM) *
Mike;
Eric
No worries -- it'll be a couple of weeks before I make that purchase, anyway. Thanks for the help, M
mbrown3039   Daily driver mods?   Feb 15 2009, 05:19 PM
dw914er   for reliability, just keep up on basic maintenance...   Feb 15 2009, 05:25 PM
r_towle   Add AC or you will sweat and smell. along with a t...   Feb 15 2009, 06:20 PM
orange914   pertronix electronic ignition -$100   Feb 15 2009, 06:32 PM
Hammy   pertronix electronic ignition -$100 :agree...   Feb 15 2009, 11:54 PM
bryanf   I drove my daily for about 10 yrs as a commuter. ...   Feb 15 2009, 07:38 PM
ericread   I've driven my 914 as a DD for about three yea...   Feb 15 2009, 07:58 PM
mbrown3039   #2. Install a CHT. You can get a good probe, met...   Feb 15 2009, 08:09 PM
ericread   Thanks -- just the kind of list I was looking for...   Feb 15 2009, 08:38 PM
mbrown3039   The Micro-1000 CHT is from Aircraft Spruce, a com...   Feb 16 2009, 12:45 AM
ericread   The Micro-1000 CHT is from Aircraft Spruce, a co...   Feb 16 2009, 08:54 AM
mbrown3039   Mike; I'm at work today and I don't have...   Feb 16 2009, 12:45 PM
Nana's_914   I had a vapor lock issue on a freeway commute home...   Feb 16 2009, 01:19 PM
mbrown3039   I'm at work today and I don't have the do...   Feb 16 2009, 01:40 PM
ericread   I'm at work today and I don't have the d...   Feb 16 2009, 03:13 PM
rascobo   Some things to include along with basic tools are:...   Feb 15 2009, 08:54 PM
ChrisNPDrider   My 914 was a daily driver for 8 months, and the up...   Feb 15 2009, 09:00 PM
mbrown3039   There is another I read on the board here, want ...   Feb 15 2009, 09:06 PM
Dr. Roger   first things first. brakes. 33 year old rubber b...   Feb 15 2009, 09:17 PM
dw914er   agreed on the fire extinguishers. Just in case, i ...   Feb 16 2009, 05:00 AM
Spoke   Lots of good suggestions here. In general almost...   Feb 16 2009, 08:05 AM
Heeltoe914   Remove every ground strap and wire and clean its c...   Feb 16 2009, 01:35 PM
Eric_Shea   Run by Renegade and see Steve and Toast. They...   Feb 16 2009, 02:35 PM
jim_hoyland   All the above make good sense: My $0.02: 1. ...   Feb 16 2009, 03:02 PM
ericread   Here's the price and part numbers for the CHT:...   Feb 16 2009, 07:42 PM
SGB   Flush the brake fluid NOW. New spark plug wires (...   Feb 17 2009, 04:25 PM
- Lo-Fi Version Time is now: 16th July 2025 - 05:57 PM
