first gear replacement, replacing dog tooth - opinions on slider |
zeezee |
Feb 21 2009, 06:12 PM
Member Group: Members Posts: 115 Joined: 16-October 08 From: san ramon, ca Member No.: 9,651 Region Association: Northern California |
First is gone ... grinds going in, pops out when I let the clutch out.
I've done lots of linkage adjustments, replacements, etc. etc. Followed the Pelican Tech article to open the tranny and check out the gears. This is what I see... dog tooth: slider: I'm assuming I'll be replacing the syncro ring, and the dog tooth gear. And the slider is still ok. Yes? No? Any recommendations on where to pick up the parts? |
toon1 |
Feb 22 2009, 10:30 AM
Senior Member Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 |
The factory gasket is better and cheaper than a tube-a-goo...and you can get the end cap off next time.... (IMG:style_emoticons/default/biggrin.gif) The back end of the tranny's are not that bad for leaks. Make sure everything is clean and use a good sealer like yamabond or red permatex (565 I think) Guess I should have clarified. I use both, when using the sealer, I go very light, just enough to make a seal but not to squish it into the case. The permatex red is anarobic so it comes apart with no problems. |
Lo-Fi Version | Time is now: 7th June 2024 - 08:52 AM |
