> How low...can you go. And how did you do it?
ottox914
post Mar 2 2009, 09:55 PM
The glory that once was.
Thinking of lowering the 914 some more. I should be getting the new turbo motor done. 2 seasons ago I had it REAL low, so low that, while on a smooth auto cross course, the front "A" arm did not hit the pinch weld on the tub, but on the road, a good bump would = a big clunk. I confirmed this by putting some tape on the "A" arm and seeing it damaged, proved my theory. A little to low. I know if you go super low, the camber curve gets out of whack. I liked the look of the car lower, and it seemed to handle well also. I'd consider making a new lower "A" arm, but was wondering what I could learn from those who have been there/done that. I'm running a SA koni insert in front from something or other, that Jason Burkett from Paragon sold me, I needed to shorten the strut tubes about 5/8" to make them fit. The front is now low enough such that with the Koni snubbers, and a zip tie on the shock shaft, that during normal driving I have maybe 1/4' to the snubber. Rear ride height is currently set off the front, to achieve best possible corner balance/cross weights. As the Koni's are several seasons old, I'd not be adverse to sending them in for a re-build, and having them shortened, F and R. Anyone convert the rears to use a more commonly available "eye" style shock? Show me that too...
thanks-
Joe Ricard
post Mar 3 2009, 08:27 PM
CUMONIWANNARACEU
Running a Koni race insert I think 8610-1473. I cut and sectioned the strut tubes two inches. HOWEVER I am running ride hieght of about 4 1/2" at the lift donuts. Under full compression I am smashing the zip tie against a standard Koni foam snubber.
- Lo-Fi Version Time is now: 16th June 2024 - 08:59 PM
