turnaround89 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 671 Joined: 17-May 08 From: Rockford, Illinois Member No.: 9,067 Region Association: Upper MidWest ![]() |
I just put my fuel pump back in and had some questions about the S R and D on it. I understand that the S, is the line from the tank. the R is return from the carbs, and the D is Damper, however, is the D the line that fuel runs through to the carbs? Its the only remaining option i have for lines, just wanted to make sure?
type47 |
Viermeister ![]() ![]() ![]() ![]() Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region ![]() |
Careful. It sounds like you are using a D-jet fuel pump with carbs. D (and L-) -jet pumps should be too much pressure (about 30 psi) for carbs unless you have some sort of pressure reducer. I think carbs use fuel pumps that produce pressure in the 5 psi range.
"D" stands for druck which is German for pressure so thats the pressure port. |
Lo-Fi Version | Time is now: 14th July 2025 - 04:26 AM |
