> Fuel Pump, Supply, Return, Damper
turnaround89
post Mar 5 2009, 01:23 PM
I just put my fuel pump back in and had some questions about the S R and D on it. I understand that the S, is the line from the tank. the R is return from the carbs, and the D is Damper, however, is the D the line that fuel runs through to the carbs? Its the only remaining option i have for lines, just wanted to make sure?
effutuo101
post Mar 5 2009, 02:46 PM
Here is a link for the products I am useing.
Fuel pump. 2-15psi, a spring to adjust from 15-70psi
a regulator to manage my flow with a return line to the tank to keep the gas at the regulator as cold as possible. I am waiting on my carbs to get back on so I can dial in the system.
Phoenix red will be running the same regulator and return system.
With the pressure gague right on the regulator, you can dial this in for your carbs.
http://www.aeromotiveinc.com/products.php
p/n 13301 for the bypass regulator
- Lo-Fi Version Time is now: 14th July 2025 - 02:50 AM
