> suby hotrod motors, Probably cost equal to a really good porsche 6
charliew
post Feb 24 2009, 09:50 AM
http://forums.nasioc.com/forums/showthread.php?t=1699103
These motors are probably 15-20k once they reach the track. Just a offhand guess. As my son has spent 13k on a street motor with no tranny mods. Just motor, ported heads, bigger cams, 100mm bore, open source tuning with datalogging and utec piggyback, bigger injectors, bigger fuel pump, bigger oil pump, front mount ic, 8qt oil pan, true cold air intake and a 30r rotated turbo at 26 psi. Conservative tune about 425awhp. Also no water or alcohol injection yet.
charliew
post Mar 3 2009, 10:15 PM
I have seen a custom itb setup on a suby but it was also a turbo. The 02 up wrx and sti uses a tumble generator valve that looks sorta like a itb but it's a butterfly valve that is controled by the ecu with motors and feedback to increase the velocity in the intake path at low rpm. The tgv is one of the first things that everyone guts to give more flow. They remove the butterflies and shaft and weld up the holes. The tgv is only on us domestic market motors. The jdm stuff just uses a solid casting intake that doesn't have the tgvs. The tgvs set on the heads before the intake. The uneducated would think they were looking at itbs if the upper intake manifold is off.
One other nasioc technique is to use a late 2.5 na intake as it has a bigger plenum to hold more reserve pressure to help on the top end performance.
It really takes about 10k on top of the 2000.00 to 3000.00 shortblock with forged internals (a sti stock shortblock has cast pistons good for about 20 psi until you get bad gas) to make 500 awd hp on a usually overbored 2.5 suby.
cams 1000.00 4 of course
heads with bigger valves and ported 3000.00 maybe including cams for the non cosworth variety
1500.00 standalone ecu, usually speed density no maf just 3 bar map
bigger injectors 850.00
bigger fuel supply 300.00
water/ alcohol injection 800.00
good header, uppipe, down pipe, wastegate, 3 or 4 inch exhaust at least 1000.00 less on the 914 ebay headers are about 240.00
good clutch, flywheel 600.00
bigger oil pan for reliability 400.00 to 600.00
bigger turbo to provide about 30 psi 3500.00
There is no way without juice you can make 500 awd hp with the sti turbo and some magic tuning and if somehow you did it would be so on the edge the first bad gas you bought would do the stock cast pistons in.
Really though as wrx914 said a good 300 hp that doesn't need to be worked on once a month is all most people need to have lots of fun. UNTIL the zo6 comes up in the rearview mirror, then you remember back when it was a type 4. Beep Beep
DBCooper
post Mar 5 2009, 05:21 PM
14's in the 13's with ATTITUDE
QUOTE(charliew @ Mar 3 2009, 08:15 PM) *
Beep beep my ass.
I just can't see it, so I may have to be taught this one the hard way.
Actually the stock STI motors are 300hp, and it should do 5-10 percent better with a freed up intake, no cats and a dyno tune. But even at only 300hp that's what? 7lbs per hp? Not so bad. Stock motor, so oil changes at 7500 miles, spark plugs at 30,000, cam belt at 105,000, just like your family car.
So what's that Z06's lbs/hp ratio, anyway?
Found it, the 2008 Z06 is 6.3 lbs/hp. He'd have a small power advantage, but same ballpark. So no beep beep, especially on curvy roads.
charliew   suby hotrod motors   Feb 24 2009, 09:50 AM
cobra94563   porsche motor w/ 400+hp is more... now..an SBC...   Feb 24 2009, 10:12 AM
Vacca Rabite   porsche motor w/ 400+hp is more... now..an SBC.....   Feb 24 2009, 10:45 AM
J P Stein   Great power.... then comes the age old hot rod que...   Feb 24 2009, 10:31 AM
pktzygt   Great power.... then comes the age old hot rod qu...   Feb 24 2009, 10:37 AM
WRX914   Well this is a loaded question... A hot rod suby ...   Feb 26 2009, 02:14 PM
fiid   Well this is a loaded question... <<chopped...   Feb 27 2009, 08:10 PM
WRX914   Forgot to mention.... Because the engine complet...   Feb 26 2009, 02:21 PM
SnailPerformance   Forgot to mention.... Because the engine comple...   Mar 5 2009, 05:07 PM
DBCooper   At what point do you consider a Porsche engine to ...   Feb 26 2009, 03:14 PM
iamchappy   I may need to rethink my engine, sell my 400hp tur...   Feb 26 2009, 03:32 PM
turboman808   Yeah the subaru motor is so freakin cheap. But da...   Feb 26 2009, 03:40 PM
Brett W   Hell a 250hp 2.0 flat six is well into the 30K ran...   Feb 26 2009, 03:52 PM
DBCooper   Hell a 250hp 2.0 flat six is well into the 30K ra...   Feb 27 2009, 05:40 AM
charliew   Any suby powered 914 should be easier to handle th...   Feb 26 2009, 04:20 PM
DBCooper   I may need to rethink my engine, sell my 400hp tu...   Feb 26 2009, 04:24 PM
charliew   I see no reason to buy a renegade kit. But I like ...   Feb 27 2009, 12:11 AM
plymouth37   Subie is cheaper hands down. I have about 3K into ...   Feb 27 2009, 01:59 AM
grantsfo   Subie is cheaper hands down. I have about 3K into...   Feb 27 2009, 03:27 PM
Brett W   Turbos are the best thing for street cars. NA mot...   Feb 27 2009, 02:28 PM
turboman808   Turbos are the best thing for street cars. NA mo...   Feb 27 2009, 02:55 PM
effutuo101   I may need to rethink my engine, sell my 400hp t...   Feb 27 2009, 03:30 PM
WRX914   You do not need a aftermarket ECU. You simply nee...   Feb 27 2009, 07:22 PM
charliew   A 2.0 wrx converted to a 2.5 shortblock is called ...   Mar 3 2009, 12:02 AM
WRX914   A 2.0 wrx converted to a 2.5 shortblock is called...   Mar 3 2009, 03:05 PM
r_towle   please explain a few things. $1850 buy a shor...   Mar 3 2009, 04:11 PM
DBCooper   please explain a few things. $1850 buy a sho...   Mar 3 2009, 05:25 PM
fiid   Is it possible, or has anyone done it, to put a c...   Mar 5 2009, 04:34 PM
brant   It always comes down to priorities. try going vint...   Mar 3 2009, 04:25 PM
DBCooper   It always comes down to priorities. try going vin...   Mar 3 2009, 05:29 PM
grantsfo   It always comes down to priorities. try going vin...   Mar 16 2009, 11:23 AM
charliew   I have seen a custom itb setup on a suby but it wa...   Mar 3 2009, 10:15 PM
SnailPerformance   I have seen a custom itb setup on a suby but it w...   Mar 5 2009, 05:17 PM
charliew   [quote name='charliew' post='1141041' date='Mar 3...   Mar 14 2009, 12:44 PM
DBCooper   [quote name='SnailPerformance' post='1141879' dat...   Mar 16 2009, 06:24 AM
DBCooper   Really though as wrx914 said a good 300 hp that d...   Mar 5 2009, 05:21 PM
WRX914   I stand corrected... Charlie is correct. I calle...   Mar 5 2009, 04:20 PM
charliew   DB think about this, you are running about 80 on 3...   Mar 8 2009, 10:53 AM
DBCooper   Shift "down" to fifth? The STI engine I...   Mar 8 2009, 03:28 PM
WRX914   Last year I ran a hopped up Camaro SS that sounded...   Mar 9 2009, 01:52 PM
SnailPerformance   ill run just about anything in my car.. 505 z06 su...   Mar 9 2009, 10:41 PM
charliew   I don't know what year gsx-r1000 you are playi...   Mar 11 2009, 01:32 PM
biosurfer1   Next time I'm in Vegas, I'm going to need ...   Mar 11 2009, 01:59 PM
DBCooper   No, it's not a Gixxer, but you and a friend ca...   Mar 11 2009, 06:20 PM
charliew   Only thing I found on a nasioc search on treefroga...   Mar 16 2009, 10:53 AM
DBCooper   Only thing I found on a nasioc search on treefrog...   Mar 17 2009, 06:25 AM
biosurfer1   Holy moly....$2100/HOUR?!?!?   Mar 16 2009, 12:31 PM
grantsfo   Holy moly....$2100/HOUR?!?!? Hey th...   Mar 16 2009, 12:52 PM
charliew   I also love the sound of a flat six at 7500 but I ...   Mar 17 2009, 10:25 AM
DBCooper   No, Charlie, wasn't referring to you, it was T...   Mar 17 2009, 01:37 PM
charliew   My third, a 58 vw, was a college car to replace th...   Mar 17 2009, 02:19 PM
- Lo-Fi Version Time is now: 8th July 2025 - 09:47 PM
