first gear replacement, replacing dog tooth - opinions on slider |
zeezee |
Feb 21 2009, 06:12 PM
Member Group: Members Posts: 115 Joined: 16-October 08 From: san ramon, ca Member No.: 9,651 Region Association: Northern California |
First is gone ... grinds going in, pops out when I let the clutch out.
I've done lots of linkage adjustments, replacements, etc. etc. Followed the Pelican Tech article to open the tranny and check out the gears. This is what I see... dog tooth: slider: I'm assuming I'll be replacing the syncro ring, and the dog tooth gear. And the slider is still ok. Yes? No? Any recommendations on where to pick up the parts? |
Dr Evil |
Mar 8 2009, 04:04 PM
Send me your transmission! Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
OK, popping out means that either the groove in the slider is flattened, the synchro band does not have enough spring tension, or that the band and blocks have a problem.
From your pic it looks like the synchro band retaining groove is adequate, but its a pic and I can only deduce so much from it. I would be happy to inspect your slider and see if I have a cheaper replacement used one that is in better shape if yours turns out to be poo. Or, I can jsut look at it for you and give you my opinion (IMG:style_emoticons/default/wink.gif) |
Lo-Fi Version | Time is now: 7th June 2024 - 09:18 PM |
