| dkjens |
Mar 8 2009, 11:47 AM
Member ![]() ![]() Group: Members Posts: 159 Joined: 24-November 08 From: Pasadena, CA Member No.: 9,785 Region Association: None |
So, I just picked up another 914 tranny, so now I have the one in my '73 and this newly acquired tranny. I will have a local shop owner and really great friend build me one good 914 tranny with the gear spacing for V8s. What can I do (spend) money on during this transmission rebuild to make it as strong as possible, in addition to the billet intermediate plate?
I figure we'll take both trannys apart, lay out the gears, synchros etc., pick the best parts (hope both 2nd gear sets are in good shape), 1st and 2nd stays stock, reversed 4th becomes 3rd, reversed 3rd becomes 4th and reversed 2nd becomes new 5th. New bearings and synchros if needed, although they work fine in the tranny in my car. So, definately, the billet intermediat plate, there's $400.00, do I need oil cooler/pump and which system would be the best bang for the buck? The car is/will be a fun street car, 911SC brakes all around, Kennedy 9" clutch, at the moment mild Chevy 283 (est. 200-250HP) but later in the year Chevy 350 (400-500HP) so may look for ceramic clutch plate (with springs if possible for a little engage slippage). I have never been on the track so I can guarantee that I am a lot less agressive driver than most on this board (IMG:style_emoticons/default/driving.gif) |
| jimkelly |
Mar 8 2009, 08:09 PM
Delaware USA ![]() ![]() ![]() ![]() Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
are you gonna be running fat rubber ( flared car ) or fat sticky rubber?
i hear big HP and traction will be your transaxle's enemy. i hear a 930 box run upside down is the hot lick for big horsepower and grippy rubber. jim |
| Todd Enlund |
Mar 8 2009, 08:36 PM
Resident Photoshop Guru ![]() ![]() ![]() ![]() Group: Members Posts: 3,252 Joined: 24-August 07 From: Reed (Portland), Oregon Member No.: 8,032 Region Association: Pacific Northwest |
are you gonna be running fat rubber ( flared car ) or fat sticky rubber? i hear big HP and traction will be your transaxle's enemy. i hear a 930 box run upside down is the hot lick for big horsepower and grippy rubber. jim I hear a 930 box run upside down doesn't oil the pinion properly... I hear you should machine the case to flip the ring. (IMG:style_emoticons/default/confused24.gif) |
dkjens Building strong 914 tranny Mar 8 2009, 11:47 AM
d914 Im not a tranny guy but some take first out, other... Mar 8 2009, 12:07 PM
Cap'n Krusty How are you gonna reverse 2nd? You have a 904 mai... Mar 8 2009, 12:44 PM
dkjens I know not to use 1st except for as described. Is ... Mar 8 2009, 12:48 PM
Th... Mar 8 2009, 01:05 PM
Bruce Hinds The wide gear spacing works well with the V8. I t... Mar 8 2009, 03:32 PM
ConeDodger If you are thinking about 500HP you can build a st... Mar 8 2009, 04:46 PM
Todd Enlund
If you are thinking about 500HP you can build a s... Mar 8 2009, 08:06 PM
Cap'n Krusty Lest we forget, 915s have a nasty habit of explodi... Mar 8 2009, 07:27 PM
I hear a 930 box run upside down doesn't oil ... Mar 8 2009, 09:28 PM
Dr. Roger IMHO, the chevy 283 and the rare 302 are the perf... Mar 8 2009, 09:18 PM
dkjens Well, looks like I'll just put a little money ... Mar 8 2009, 09:26 PM
messix
Well, looks like I'll just put a little money... Mar 8 2009, 09:39 PM
Bruce Hinds The 283 and 302 are great motors, but you can get ... Mar 9 2009, 10:22 AM
dkjens So if I'm looking for a 327 block for a small ... Mar 9 2009, 01:59 PM
jmmotorsports
So if I'm looking for a 327 block for a small... Mar 9 2009, 02:13 PM
yokesman
So if I'm looking for a 327 block for a smal... Mar 9 2009, 04:52 PM
MZM Thinking out of the box, have you looked at the Su... Mar 9 2009, 05:05 PM
yokesman this is a subject that would be helpful to me in g... Mar 9 2009, 05:08 PM
messix early 327 block is 1967 and older. you can find th... Mar 9 2009, 06:02 PM
Bruce Hinds 350 and 327 were both a 4" bore and the diffe... Mar 9 2009, 11:11 PM
messix
350 and 327 were both a 4" bore and the diff... Mar 9 2009, 11:41 PM
yokesman per wiki ,
4.8 and 5.3 gm engines share the same b... Mar 10 2009, 02:12 PM
jimkelly oh - just get a brand new crate 350 and pop it in ... Mar 10 2009, 07:38 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:04 PM |
