> 1975 Porsche 914 1.8 liter, fuel pump
nigolusa
post Mar 21 2009, 11:58 AM
nigolusa
Group: Retired Members
when first turning the key, not all the way, is the fuel pump supposed to be working?
Before installing, tested it and it spun.
Now after completing the fuel tank installation, lines etc., I cannot hear it functioning.
Is this a relay problem?
Or does it spin after the engine starts?
(IMG:style_emoticons/default/headbang.gif)
Cevan
post Mar 21 2009, 01:23 PM
Answer: no. With the key in the on position, the fuel pump will only run if the flapper on the airflow meter is pushed open (even just a little). When the key is the start position, the dual relay will power the fuel pump. Once the engine starts abd the key returns to the on position, air entering the AFM will keep the flap open and the fuel pump powered.
You can test the pump by turning the key to on and then pushing the flap open. That should make it run. You should hear the dual relay click on also.
nigolusa
post Mar 21 2009, 02:54 PM
nigolusa
QUOTE(Cevan @ Mar 21 2009, 12:23 PM) *
Thank you Kelly and Chris. I will try and see what happens (IMG:style_emoticons/default/grouphug.gif)
- Lo-Fi Version Time is now: 2nd April 2026 - 12:56 PM
