Clutch job wisdom |
Clutch job wisdom |
JeffBowlsby |
Apr 2 2009, 01:42 PM
914 Wiring Harnesses Group: Members Posts: 8,533 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
So my clutch has just started to slip and it chatters sometimes on launch. I thought I would first adjust it to see if it helps, but may need a new clutch. I have done thsi job before with all the recommended felts washers, flywheel O-rings etc. I don't seem to be having any leakage, burning smells and I have receipts from when I bought the car saying it has a recent new flywheel.
I will do whatever is necessary once I am in there, but don't want to remove the flywheel or do anything not needed. Assuming nothing is worn or broken (I will replace or resurface things if they are worn), does it make sense that I can get by with just replacing the clutch disk? Can I reuse the pressure plate, T/O bearing, T/O bearing guide clips? Pelican recommends the 6-spring disk: "We recommend using the 911 clutch package in the 914, as it gives the clutch a better feel." I tried the 6-spring disk once and it was fine of course, but what is the problem with using the stock 4-spring disk (its $125 cheaper)? My car is a daily driver street-use only and with the stiffer disk I wonder if the stronger springs contribute to clutch-tube breakage problems. Help! |
Shade Tree |
Apr 2 2009, 01:53 PM
Member Group: Members Posts: 260 Joined: 18-December 08 From: Springfield, Oregon Member No.: 9,860 Region Association: Pacific Northwest |
I've been told to at least replace the felt washer on the pinion shaft, the plastic bushing behind the fulcrum for the throw out bearing arm and the bushings on each side of the throw out bearing. If you end up having the flywheel turned, make sure that the bolts that hold on the flywheel don't stick out farther than the surface of the flywheel. I had to grind off the tops of the bolts. That last part was new to me but came from a very trusted source.
Lo-Fi Version | Time is now: 6th June 2024 - 10:41 PM |
