FourBlades |
From Wreck to Rockin ![]() ![]() ![]() ![]() Group: Members Posts: 2,056 Joined: 3-December 07 From: Brevard, FL Member No.: 8,414 Region Association: South East States ![]() ![]() |
I was test fitting my doors before painting them and noticed this:
Driver side. ![]() Passenger side. Attached image(s) ![]() |
FourBlades |
I did use a brace bolted to the upper seat belt mounting point and the lower hinge plate. I think the brace I used must have been too weak. It was made from 1 inch square tubing welded to a (pretty small) turn buckle. It is also possible I just screwed up the sheet metal at the rear of the door openings because I did a lot of welding in these areas. I should have re-fitted the doors while working on the door jambs. (IMG:style_emoticons/default/headbang.gif) Should I reassemble it and see if it aligns correctly? Any measurements I could do using simple tools to see if the whole car is screwed up? Arrrghhh!!! John |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,285 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
Any measurements I could do using simple tools to see if the whole car is screwed up? http://www.914world.com/specs/bodydims.php |
Lo-Fi Version | Time is now: 1st August 2025 - 06:32 PM |
