Help rear wheel bearing whine |
js2bugu |
Mar 17 2008, 02:41 PM
Newbie Group: Members Posts: 6 Joined: 20-October 04 From: Concord,Ca Member No.: 2,977 |
I just noticed a Rear bearing whine drivers side when I turn the wheel right.
Question is how long can I run with this bearing 10 miles, 1000 miles? Any advice would be great. Thanks Adam |
Cap'n Krusty |
Apr 6 2009, 02:07 PM
Yes, the stub axle has to come out. Yes, the hub has to come out. Spray the stub axle as best you can with a good penetrant. It goes out inward. DO NOT hammer on it unless the nut is in place to protect the threads! The hub knocks out from the back, and it can be pretty reluctant to move. It usually brings the outside inner race with it. You then remove the 4 bolts holding the bearing cover in place. After that, you knock the bearing out. The inner side inner race should still be there, and that's what you hit using a large drift...... The new bearing should be drawn in with some sort of screw device. If you can't do that, you MUST hit ONLY the outer race! Once it's in, reinstall the bearing cover. After that, you draw the hub in using a screw device, and applying pressure on both the hub and THE INNER RACE of the bearing. ONLY the INNER RACE!. If you don't, or if you try to pound it together, you'll most likely destroy your new bearing. If you've paid attention, you'll probably do just fine. Good luck! The Cap'n
Lo-Fi Version | Time is now: 10th June 2024 - 08:28 PM |
