> Door gaps are not even any more!, Now what???
FourBlades
post Apr 4 2009, 01:31 PM
From Wreck to Rockin
I was test fitting my doors before painting them and noticed this:
Driver side.
Passenger side.
FourBlades
post Apr 6 2009, 11:52 AM
Mark: I did a fair amount of seam welding on mine. Maybe 25% of the tops
and less of the bottoms. I also did the seam welding in a short time. Part of
the problem is that I had finally learned to make a really pretty seam weld
so I think I just went overboard.
The top still fits pretty well. It takes a little effort to lock the front latches.
I am going to check it again to see if the windshield frame is bending. Man
worrying about that is going to keep me from sleeping at all at work today...
How do you use a porta power to stretch a car body?
Pete: I am sure that is the thread I was reading. How did your guy know
where to jack up your car? I wonder if your car naturally stretches when
on jack stands because of the weight overhanging the front and rear jack
stand points? Maybe you need that stretch to counter act the shrinkage?
It would be nice to get this down to a repeatable science, for the sake of
future 914s...
John
horizontally-opposed
post Apr 6 2009, 12:33 PM
QUOTE(FourBlades @ Apr 6 2009, 10:52 AM) *
Experimentation + years and years of working with metal.
He welded it cold and was super mindful of the potential for problems others had experienced -- and still got shrinkage. Fortunately, he knew what he was doing and was able to fix the problem. Both doors fit up nicely and close perfectly. The final test will be the windows...
pete
Wes V
post Apr 6 2009, 03:01 PM
I think something to think about would be to do one side at a time.
Put jack stands at the front and rear of the door opening.
Put a floor jack at the front so it just barely supports the front weight.
Put a floor jack at the rear so that it also barely supports the weight. Then lower it slightly.
Remove the rubber seal on the door, close the door and measure the gaps. That way you could close the door while doing the welding to see how stuff is moving around.
My guess is that while welding and the top of the long is hot, the rear of the car would sag downward and touch the floor jack you have there. Don't raise the jack!!!!
As the long cools, the rear would raise again, off of the jack.
The weight of the cantilevered rear section should limit how much the top of the long shrinks.
What I'm getting at is that you should maybe "preload" the longitudinal.
Adding a brace, although helpfull wouldn't preload the section (unless you screwed it outward real tight) and as a result, when you remove the brace, it would spring back and close the top gap.
Think about this; when a frame shop is trying to get a frame straight, they pull (or push) it past the point where they want it to be.
Of course, this is just me talking out the side of my mouth. I've yet to weld in an Engman.
Wes
FourBlades   Door gaps are not even any more!   Apr 4 2009, 01:31 PM
FourBlades   The gaps were ok before I welded in my Engman kit....   Apr 4 2009, 01:35 PM
ConeDodger   The gaps were ok before I welded in my Engman kit...   Apr 4 2009, 01:48 PM
SirAndy   I have also heard of putting bracing in the door ...   Apr 4 2009, 02:02 PM
SirAndy   Now WTF do I do??? Put the car on a lift, open t...   Apr 4 2009, 02:05 PM
FourBlades   > Put the car on a lift, open the doors and use...   Apr 4 2009, 02:12 PM
FourBlades   I did use a brace bolted to the upper seat belt mo...   Apr 4 2009, 02:09 PM
SirAndy   Any measurements I could do using simple tools to...   Apr 4 2009, 02:36 PM
Richard Casto   I did use a brace bolted to the upper seat belt m...   Apr 6 2009, 09:19 AM
JazonJJordan   I did use a brace bolted to the upper seat belt m...   Jul 29 2009, 11:03 AM
Bartlett 914   I feel your pain. I repaired my 75 when I got it i...   Apr 4 2009, 03:11 PM
FourBlades   Thanks man...did you have any trouble getting your...   Apr 4 2009, 03:26 PM
sww914   It will be very difficult or impossible to find an...   Apr 4 2009, 03:48 PM
FourBlades   According to wikipedia, steel expands .00000645 in...   Apr 4 2009, 04:03 PM
Wes V   I've got a question for the author of this str...   Apr 4 2009, 05:45 PM
FourBlades   Wes, This is a really good question. I went out ...   Apr 4 2009, 06:14 PM
drive-ability   I had that happen as well when I installed some st...   Apr 4 2009, 06:43 PM
r_towle   The A pillar, at least the part that the door hing...   Apr 4 2009, 07:29 PM
FourBlades   Rich, Thanks for the suggestion. Have you tried ...   Apr 4 2009, 07:40 PM
r_towle   Yes I have done it. Push on the outer rear b-pilla...   Apr 4 2009, 07:53 PM
FourBlades   OK, cool, I will try it tomorrow. Thanks....John   Apr 4 2009, 08:23 PM
Bartlett 914   :popcorn:   Apr 5 2009, 11:08 AM
charliew   I would think the passenger side will be easier to...   Apr 5 2009, 11:28 AM
FourBlades   Charlie, Thanks for the suggestions. I was hopi...   Apr 5 2009, 11:52 AM
horizontally-opposed   I am pretty sure I read on some forum that a guy ...   Apr 6 2009, 10:10 AM
Richard Casto   I am pretty sure I read on some forum that a guy...   Apr 7 2009, 06:54 AM
charliew   About thirty years ago I torch welded the floors i...   Apr 5 2009, 12:13 PM
Wes V   I'm trying to get my mind around this whole ...   Apr 6 2009, 09:08 AM
McMark   In my experience, this is the problem, John. I r...   Apr 6 2009, 09:56 AM
andys   When I welded my Engman kit, I measured my door ga...   Apr 6 2009, 10:39 AM
6freak   I was test fitting my doors before painting them ...   Apr 6 2009, 10:42 AM
FourBlades   Mark: I did a fair amount of seam welding on mine...   Apr 6 2009, 11:52 AM
horizontally-opposed   How did your guy know where to jack up your car? ...   Apr 6 2009, 12:33 PM
Wes V   I think something to think about would be to do on...   Apr 6 2009, 03:01 PM
Wes V   Fortunately, he knew what he was doing and was ab...   Apr 6 2009, 03:03 PM
horizontally-opposed   Fortunately, he knew what he was doing and was a...   Apr 6 2009, 03:39 PM
FourBlades   Mr. C: I was wondering about that too. If I neede...   Apr 6 2009, 11:56 AM
6freak   Mr. C: I was wondering about that too. If I need...   Apr 6 2009, 12:30 PM
FourBlades   Slim line hinges may work....hmm.. Great, windows...   Apr 6 2009, 02:56 PM
burton73   John, Your post was freaking me out all weekend. ...   Apr 6 2009, 03:20 PM
FourBlades   Bob: Your door gap looks pretty good. Sounds lik...   Apr 6 2009, 05:58 PM
r_towle   So, To use a hydraulic unit to spread the door, y...   Apr 6 2009, 06:33 PM
FourBlades   Rich, Which part of the rear door jamb do you res...   Apr 6 2009, 06:52 PM
r_towle   outer edge so you are pushing against the fender (...   Apr 6 2009, 07:14 PM
charliew   Adding the material will fix the small door but I...   Apr 6 2009, 07:18 PM
Wes V   It sure would be nice if somebody stepped up with ...   Apr 6 2009, 07:56 PM
FourBlades   Richard, I think I made the same mistake when I p...   Apr 7 2009, 07:44 AM
Richard Casto   John, I think part of the problem is that if I kn...   Apr 7 2009, 08:13 AM
charliew   Welding never spreads any structure. It will alway...   Apr 7 2009, 10:08 AM
Richard Casto   Welding never spreads any structure. It will alwa...   Apr 7 2009, 12:55 PM
charliew   The fact that the engman kit covers the top and in...   Apr 7 2009, 01:12 PM
Bartlett 914   Heating the driver side bottom might help close j...   Apr 7 2009, 01:30 PM
charliew   Heating the driver side bottom might help close ...   Apr 8 2009, 12:18 AM
McMark   John, I've used a PortaPower between the front...   Apr 7 2009, 05:48 PM
atomix8   I realize I'm thread hijacking, AND pulling ou...   Jul 27 2009, 07:54 PM
tracks914   Yours looks easy to fix. Your door is too low at ...   Jul 28 2009, 08:46 PM
atomix8   Yours looks easy to fix. Your door is too low at...   Jul 29 2009, 05:42 PM
r_towle   Yours looks easy to fix. Your door is too low a...   Jul 29 2009, 07:12 PM
rick 918-S   [quote name='atomix8' post='1196947' date='Jul 29...   Jul 29 2009, 08:16 PM
- Lo-Fi Version Time is now: 1st August 2025 - 06:32 PM
