FourBlades |
From Wreck to Rockin ![]() ![]() ![]() ![]() Group: Members Posts: 2,056 Joined: 3-December 07 From: Brevard, FL Member No.: 8,414 Region Association: South East States ![]() ![]() |
I was test fitting my doors before painting them and noticed this:
Driver side. ![]() Passenger side. Attached image(s) ![]() |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
So,
To use a hydraulic unit to spread the door, you need to make a perfectly matching cawl, scribed to the door jamb. The front cawl should apply pressure to the exact spot that the hinges are mounted. I have done this with the door mounted and the door stay removed. This allows you to open the door wide enough to apply the pressure, and once the pressure has been applied, you gently pull the rear fender. Then remove the jack and cawls and test the door. Rinse and repeat. On the side with a large door gap, if it was me, I would weld on some welding rod to the back of the door and grind that down and call it a day. This is a standard old school bodyman trick...both of them. Rich |
Lo-Fi Version | Time is now: 1st August 2025 - 06:32 PM |
