> Carb Crust in Float Bowls???, Webber 40ida3c
Mike D.
post Jan 29 2004, 06:58 PM
OK, It runs now, and pretty good too!
I got carb kits just clean and freshen up the webbers on the 6 engine while it is out of the car. Well, when I opened them up I found in one float bowl some crusty yellowish white stuff. I sprayed with some carb cleaner brushed it with a tooth brush wiped it out and blew it with some air and more white crust appeared. What is this and how do I get rid of it? This stuff could obviously clog up jets, which is no good.
I also found that one of the floats is dented, like some PO (IMG:style_emoticons/default/smash.gif) droped it and steped on it, I floats though, should I be concerned about that?
TIA,
Mike D.
Downunderman
post Jan 29 2004, 11:17 PM
Region Association: Australia and New Zealand
The way to fix this permanently is to strip the carbs completely and have them chromate dipped and the surface converted. The carbs end up looking a bit army green but the crustiness will go away. A lot of aricraft places do the dipping.
Mike D.   Carb Crust in Float Bowls???   Jan 29 2004, 06:58 PM
Aaron Cox   sounds like some evil bacteria! :lol:   Jan 29 2004, 06:59 PM
ArtechnikA   <...   Jan 29 2004, 07:16 PM
Howard R   The way to fix this permanently is to strip the ca...   Jan 29 2004, 11:17 PM
need4speed   Wow. This sounds so familliar to me. My 34-PICT ...   Jan 30 2004, 12:41 PM
J P Stein   Carbs are made from "pot metal". .....that's a...   Jan 30 2004, 01:01 PM
ArtechnikA
- Lo-Fi Version Time is now: 1st August 2025 - 03:31 AM
