Orange 75 project, Clutch and Shifter setup |
my928s4 |
Nov 25 2007, 03:13 PM
Member Group: Members Posts: 349 Joined: 18-August 07 From: Spokane, WA Member No.: 8,018 Region Association: Pacific Northwest |
So a couple months back I posted about getting a hold of the project candidate,
feel like I have moved on from that so thought it I would post some pics on progress and I will add to this thread as time (and progress) goes on. I did not get around to stripping the car down till earlier in the month as I drove my 928 down to Sharktoberfest in LA and I was performing last minute tinkering before the drive. Anyway back to 914 subject matter, the good news is I have not found too many issues which is a relief and I can start to order parts and make some investment in tools. It is a perfect time of year for indoor projects as it is below freezing all the time now and skiing does not start here till after xmas. Surface rust and dirt in the front trunk but that is about it, will need to repiar a couple of areas around the hood seal. Chris |
charliew |
Apr 19 2009, 05:19 PM
Advanced Member Group: Members Posts: 2,363 Joined: 31-July 07 From: Crawford, TX. Member No.: 7,958 |
You might want to check out a caliper rebuild thread. Your pistons are not positioned in the correct orientation. The missing part of the piston rim faces the incoming part of the rotor when it is mounted on it's proper side. 20 degrees is the term they use when positioning each individual side. Wes V has a good thread and I'm sure there are others.
my928s4 |
Apr 20 2009, 09:03 AM
You might want to check out a caliper rebuild thread. Your pistons are not positioned in the correct orientation. The missing part of the piston rim faces the incoming part of the rotor when it is mounted on it's proper side. 20 degrees is the term they use when positioning each individual side. Wes V has a good thread and I'm sure there are others. You are correct, found this pic on Pelican. |
Lo-Fi Version | Time is now: 2nd June 2024 - 01:26 PM |
