Panamericana |
Newbie ![]() Group: Members Posts: 12 Joined: 29-March 09 From: Toronto Member No.: 10,216 Region Association: Canada ![]() |
All things being equal (and I know they never really are), would you choose a matching numbers 1.8 or a car where the PO has switched out the 1.8 for a 2.0? Does an engine switch like this devalue the car significantly?
DBCooper |
14's in the 13's with ATTITUDE ![]() ![]() ![]() ![]() Group: Members Posts: 3,079 Joined: 25-August 04 From: Dazed and Confused Member No.: 2,618 Region Association: Northern California ![]() |
The original question was if non-matching numbers devalue the car significantly. So fess up folks, when you bought the car you now own did you look to see if the numbers matched? Anyone? What's the percentage of current owners who even know if their numbers match? Or an even more basic question, how many current owners even know HOW to check if their numbers, all the numbers, match?
And in the unlikely instance that you did check the numbers, did the non-matching numbers cause you to make a lower offer for it? Maybe that should be a poll. I'd be curious to know the results, but I suspect that that apart from the 2 percent CW contingent the answer to the question will be no. Matching numbers themselves do not significantly increase or decrease the value of your car. |
dw914er |
Planning Cities ![]() ![]() ![]() ![]() Group: Members Posts: 2,365 Joined: 1-March 08 From: Yucaipa, CA Member No.: 8,763 Region Association: Southern California ![]() |
The original question was if non-matching numbers devalue the car significantly. So fess up folks, when you bought the car you now own did you look to see if the numbers matched? Anyone? What's the percentage of current owners who even know if their numbers match? Or an even more basic question, how many current owners even know HOW to check if their numbers, all the numbers, match? And in the unlikely instance that you did check the numbers, did the non-matching numbers cause you to make a lower offer for it? Maybe that should be a poll. I'd be curious to know the results, but I suspect that that apart from the 2 percent CW contingent the answer to the question will be no. Matching numbers themselves do not significantly increase or decrease the value of your car. my numbers match |
Lo-Fi Version | Time is now: 31st July 2025 - 03:38 AM |
