detoxcowboy |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa ![]() |
Anybody have any tips on cleaning out the combustion chamber by hand not bead blasting etc.. wife won't do it..
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
for the disassembled motor, use the yellow can of easy off oven cleaner.
Only leave it on for 20 minutes then wipe it all down. It takes several rinse repeat cycles to get it all, but it works. Do it outside...it stinks. If you end up with blackened areas, use straight borax (available in the laundry detergent isle) to neutralise the easy off Lye. It will clean up the pistons again to aluminum. RIch |
Lo-Fi Version | Time is now: 8th July 2025 - 03:33 PM |
