> Valve problem, This time I think I'm screwed
fitzm1
post Apr 23 2009, 11:57 AM
Just finished all the work I had planned for this spring. Bump steer kit, CB fuel pump and cleaned (rebuilt ) the carb that has been giving me problems. Seemed to be running great. As I am going up a hill near home I hear a pop and the engine sounds like a sewing machine. First I thought I had lost a gear in the tranny but that seems fine. I checked the compression and all cylinders are 120. Car starts fine but sounds like one or more of the valves are real loud. Any explanation besides the one I fear (trashed motor).
Joe I think I broke your motor.
Mike
fitzm1   Valve problem   Apr 23 2009, 11:57 AM
underthetire   Mine did the same thing yesterday. Ended up a head...   Apr 23 2009, 12:34 PM
Elliot Cannon   Collapsed lifter??? :confused:   Apr 23 2009, 12:49 PM
Scott Schroeder   What motor are you running? I had something very s...   Apr 23 2009, 12:51 PM
Cupomeat   Ok, so if all the cylinders have even compression ...   Apr 23 2009, 12:55 PM
fitzm1   Pulling the valve covers and checking the valves i...   Apr 23 2009, 01:14 PM
SGB   plugs in tight? if an exhaust stud pulled out, th...   Apr 23 2009, 08:39 PM
fitzm1   Plugs were in tight. I just checked the valve cle...   Apr 24 2009, 02:22 PM
kwales   Coupla options. Check the exhaust studs to see if...   Apr 24 2009, 09:29 PM
r_towle   Take the valve covers off, jack up the passenger s...   Apr 24 2009, 09:51 PM
euro911   ... Either way. stop running the motor..just turn...   Apr 24 2009, 10:45 PM
fitzm1   I have the car up on stands. I have checked the v...   Apr 25 2009, 09:16 AM
Bartlett 914   Is it possible that a valve could drop but snap...   Apr 26 2009, 10:13 AM
fitzm1   Is it possible that a valve could drop but sna...   Apr 26 2009, 12:20 PM
Dave_Darling   When one of my valve seats did that, it was deform...   Apr 25 2009, 11:17 PM
fitzm1   When one of my valve seats did that, it was defor...   Apr 26 2009, 04:35 PM
fitzm1   [quote name='Dave_Darling' post='1162241' date='Ap...   Apr 26 2009, 04:40 PM
euro911   I helped a guy remove a leaking exhaust to find th...   Apr 26 2009, 06:40 PM
- Lo-Fi Version Time is now: 1st May 2026 - 03:28 PM
