| fitzm1 |
Apr 23 2009, 11:57 AM
Member ![]() ![]() Group: Members Posts: 74 Joined: 21-April 08 From: Ballston lake,ny Member No.: 8,947 Region Association: None |
Just finished all the work I had planned for this spring. Bump steer kit, CB fuel pump and cleaned (rebuilt ) the carb that has been giving me problems. Seemed to be running great. As I am going up a hill near home I hear a pop and the engine sounds like a sewing machine. First I thought I had lost a gear in the tranny but that seems fine. I checked the compression and all cylinders are 120. Car starts fine but sounds like one or more of the valves are real loud. Any explanation besides the one I fear (trashed motor).
Joe I think I broke your motor. Mike |
| SGB |
Apr 23 2009, 08:39 PM
just visiting ![]() ![]() ![]() ![]() Group: Members Posts: 4,086 Joined: 8-March 03 From: Huntsville, AL Member No.: 404 Region Association: South East States |
plugs in tight?
if an exhaust stud pulled out, the exhaust leaks under the engine- but what you hear is the exhaust valve going clan-clang-clang. almost every valve concern I've had turned out to be pulled exhaust studs- which are a pretty cheap repair at an ol school VW shop |
fitzm1 Valve problem Apr 23 2009, 11:57 AM
underthetire Mine did the same thing yesterday. Ended up a head... Apr 23 2009, 12:34 PM
Elliot Cannon Collapsed lifter??? :confused: Apr 23 2009, 12:49 PM
Scott Schroeder What motor are you running? I had something very s... Apr 23 2009, 12:51 PM
Cupomeat Ok, so if all the cylinders have even compression ... Apr 23 2009, 12:55 PM
fitzm1 Pulling the valve covers and checking the valves i... Apr 23 2009, 01:14 PM
fitzm1 Plugs were in tight. I just checked the valve cle... Apr 24 2009, 02:22 PM
kwales Coupla options.
Check the exhaust studs to see if... Apr 24 2009, 09:29 PM
r_towle Take the valve covers off, jack up the passenger s... Apr 24 2009, 09:51 PM
euro911 ... Either way. stop running the motor..just turn... Apr 24 2009, 10:45 PM
fitzm1 I have the car up on stands. I have checked the v... Apr 25 2009, 09:16 AM
Bartlett 914
Is it possible that a valve could drop but snap... Apr 26 2009, 10:13 AM
fitzm1
Is it possible that a valve could drop but sna... Apr 26 2009, 12:20 PM
Dave_Darling When one of my valve seats did that, it was deform... Apr 25 2009, 11:17 PM
fitzm1
When one of my valve seats did that, it was defor... Apr 26 2009, 04:35 PM
fitzm1 [quote name='Dave_Darling' post='1162241' date='Ap... Apr 26 2009, 04:40 PM
euro911 I helped a guy remove a leaking exhaust to find th... Apr 26 2009, 06:40 PM![]() ![]() |
Lo-Fi Version | Time is now: 1st May 2026 - 03:29 PM |
