> Valve problem, This time I think I'm screwed
fitzm1
post Apr 23 2009, 11:57 AM
Just finished all the work I had planned for this spring. Bump steer kit, CB fuel pump and cleaned (rebuilt ) the carb that has been giving me problems. Seemed to be running great. As I am going up a hill near home I hear a pop and the engine sounds like a sewing machine. First I thought I had lost a gear in the tranny but that seems fine. I checked the compression and all cylinders are 120. Car starts fine but sounds like one or more of the valves are real loud. Any explanation besides the one I fear (trashed motor).
Joe I think I broke your motor.
Mike
r_towle
post Apr 24 2009, 09:51 PM
Custom Member
Take the valve covers off, jack up the passenger side of the car so that wheel is off the ground and the drivers side rear wheel is on the ground.
Put the car in 5th gear.
While laying on the ground and watching the rockers, turn the passenger wheel backwards...as if you were in reverse.
This turns the motor forwards.
You have have a broken spring, or you may have not seated a push rod correctly and once it finally did seat, that valve no longer opens (thus you loose power)
Or, you dropped a valve seat.
Either way. stop running the motor..just turn it by hand until you figure it out.
You should be able to turn the motor through all four compression strokes by hand and not feel and resistance.
RIch
fitzm1   Valve problem   Apr 23 2009, 11:57 AM
underthetire   Mine did the same thing yesterday. Ended up a head...   Apr 23 2009, 12:34 PM
Elliot Cannon   Collapsed lifter??? :confused:   Apr 23 2009, 12:49 PM
Scott Schroeder   What motor are you running? I had something very s...   Apr 23 2009, 12:51 PM
Cupomeat   Ok, so if all the cylinders have even compression ...   Apr 23 2009, 12:55 PM
fitzm1   Pulling the valve covers and checking the valves i...   Apr 23 2009, 01:14 PM
SGB   plugs in tight? if an exhaust stud pulled out, th...   Apr 23 2009, 08:39 PM
fitzm1   Plugs were in tight. I just checked the valve cle...   Apr 24 2009, 02:22 PM
kwales   Coupla options. Check the exhaust studs to see if...   Apr 24 2009, 09:29 PM
r_towle   Take the valve covers off, jack up the passenger s...   Apr 24 2009, 09:51 PM
euro911   ... Either way. stop running the motor..just turn...   Apr 24 2009, 10:45 PM
fitzm1   I have the car up on stands. I have checked the v...   Apr 25 2009, 09:16 AM
Bartlett 914   Is it possible that a valve could drop but snap...   Apr 26 2009, 10:13 AM
fitzm1   Is it possible that a valve could drop but sna...   Apr 26 2009, 12:20 PM
Dave_Darling   When one of my valve seats did that, it was deform...   Apr 25 2009, 11:17 PM
fitzm1   When one of my valve seats did that, it was defor...   Apr 26 2009, 04:35 PM
fitzm1   [quote name='Dave_Darling' post='1162241' date='Ap...   Apr 26 2009, 04:40 PM
euro911   I helped a guy remove a leaking exhaust to find th...   Apr 26 2009, 06:40 PM
- Lo-Fi Version Time is now: 1st May 2026 - 03:29 PM
